06-20-2003, 12:51 PM | #1 |
73 blazer leafs?
hello this is my first post here.
upon acceleration the rear passenger end of the blazer drops a couple of inches.i got the rear end up off the ground and i found a lot of up and down play on that same wheel , but no play forward or back.the leaf spring bushings seem to be in pretty bad shape as well, so im pretty sure i need new leafs and bushings. i just cant seem to be able to locate new leafs and bushings. i would be ok with a small lift kit if it came with new rears but i would rather just get some aftermarket leafs and bushings any help is appreciated
iamhatedinaz |
06-20-2003, 01:05 PM | #2 |
yeller
try your local auto parts store...NAPA, Checker, etc...
They should be able to order you new leafs with the bushings already installed. Welcome to the board. ...Jeff |
06-20-2003, 01:27 PM | #3 |
thx
ill call around again but they were no help last time
thx for the reply
iamhatedinaz |
06-20-2003, 02:34 PM | #4 |
www.73-87chevytrucks.com
http://www.p-s-t.com or http://www.performancesuspension.com has bushings for it. But NAPA should have OEM replacement rubber bushings.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-20-2003, 03:24 PM | #5 |
napa
ill try napa
thx
iamhatedinaz |
06-30-2003, 11:31 AM | #6 |
Where in Phoenix are you?
I live near 75th ave and Thomas. Shoot me a PM if you see this thread. Why you hated in Az?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
