04-08-2013, 10:44 AM | #1 |
Core Support Ground location ?
My front turn signals are acting weird ? I replaced the core and not sure it's grounded properly ? How is a 292 I6 grounded, my 71 with a 350 has a strap at pass side valve cover, but I don't see one on the six banger anywhere ? Thanks !
71 C-20 07 Magnum RT AWD |
04-08-2013, 12:28 PM | #2 |
Re: Core Support Ground location ?
The ground for the front clip portion of truck is a ground strap on passenger side of frame then attaching to the inside front leading where the inner fender curves downward at the front by the frame edge of the passenger side inner fender. The cab ground straps are connected to the 6cyl valve covers then attach to the firewall, the bed ground strap attaches to the 2nd from rear bed crossmember then to frame.
Paul 2 GMCPauls |
04-08-2013, 03:05 PM | #3 |
Thank you Paul!
