Old 04-08-2013, 12:15 PM   #1
wgr2112
Grabby Front Disc Brakes
A couple of months ago, I replaced the front pads on my 72 C10.
After compressing the pistons and installing pads and "self bleed" bleeder screws, I bled the brakes.
With the crappy weather, I haven't driven it much.
When I apply the brakes, the fronts lock up occasionally and the pedal seems pretty stiff.
Is it time for new calipers? I'm guessing they're pretty old, if not original.
I also thought about replacing the Master Cylinder and booster when I clean up the engine compartment.
Thoughts?
wgr2112 is offline   Reply With Quote
Old 04-08-2013, 12:18 PM   #2
71K20chevy
71K20chevy's Avatar
Re: Grabby Front Disc Brakes
How far did you compress the piston? It's never a good idea to compress them farther than you need to.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 04-08-2013, 12:20 PM   #3
wgr2112
Whenever I do brakes, I compress it all the way back with a c clamp. Otherwise the caliper won't fit with the new pads.
Same way I've done it for 20 years.
Old 04-08-2013, 12:23 PM   #4
71K20chevy
71K20chevy's Avatar
Well, the reason you shouldn't press it all the way back is because all the rust and gunk on the piston could cause it to get stuck in the caliper...sometimes it happens, sometimes it doesn't. I'd wait and get a few more opinions before replacing anything though.
71 K20
64 GMC mud truck
Old 04-08-2013, 12:25 PM   #5
wgr2112
Yeah, there's probably 30+ years of crap in there.
I've thought about replacing the whole system eventually.
All in good time. I just want it to be safe in the meantime!
