auxillary heater for shaved firewall/eliminate heater core
i did some searching but can't find anything specific on the forum.
anyone know of any type of electric auxillary heater that would fit under the dash and be able to hook up defrost/heat to be able to eliminate the heater core? kind regards
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
Re: auxillary heater for shaved firewall/eliminate heater core
Only thing i know even close is a mojave heater but it needs coolant lines for heat.But its not big so you could mount it anywhere and hide the hoses under the hood.
Junior Member
I think Summit may have a universal heater, but like stated above it would require coolant lines.
The alternators in these trucks do not put out enough amps to make using an electric heater an option I wouldn't think.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
If amps is an issue he could always do the cs144 swap.
18 Till I Die
Years back you could buy 12v underdash heaters that were designed for extra heat. They did not hook up to any vents but just blew out warm air like a hair dryer. At most they would take the chill out the cab. Maybe J.C. Whittney?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
i digress, it would be fine for coolant lines, as long as the core was self contained in the unit like the mojave one... without the big box on the firewall
![]() thanks for the input, i understand the amperage required to run an electric one. thanks again guys!!! kind regards
Have you heard of the Vintage Air units. Heater and a/c all hides under dash.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
Wide n'Low
![]() Join Date: Jan 2007
This one is similar, looks pretty nice
http://www.vintageair.com/2012catalo...Page%2049).pdf
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#9 | |
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 04-09-2013 at 03:11 PM. |
78K & 79C Jimmys
How much heat? this may help,or something like this?
http://www.princessauto.com/pal/prod...xiliary-Heater
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I know the pieces fit
Those used to be readily available for Jeeps but I haven't seen one in a while.
#12 | |
![]() Join Date: Feb 2012
dount laugh 5 cents is a big deal now a days..
As a former over the road truck driver I would say to check out the Webasto and Espar websites I'm sure that they have something for you.
http://www.webasto.us/products-and-m...html/8796.html http://www.espar.com/
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world! ![]() |
#15 |
I'm thinking you CAN get enough amps to run an electric heater.
Forgive me, my memory is a little fuzzy. A while back I was fixing an old VW bug, and looking online and talking with people on forums similar to this. Heating those old bugs was always a challenge, and many people were looking at electric options. On the bugs it just wasn't viable, because the best you could get was an 85 amp alternator, and I think we were looking at 100 amps necessary to get a decent amount of heat, more than just defrosting the windows. On a Chevy 350, I think it's possible to get alternators capable of 200 amps, that's plenty of juice to run a 1500W heater and still have enough left over to run your headlights, radio, ect ect. You couldn't do it on the stock alternator, of course, and you would need some heavy-gauge wiring, but I truly think it's possible.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
#16 |
i'm thinking of running some water bulkhead fittings behind the rear of the engine on the firewall, they'll come out right under the dash for the vintageair heater/defroster. the one with the electronic controls is only 229 bucks, so i think i'll go that route, nice and smooth/hidden
thanks for all the options/opinions that's why this site kicks a$$
#17 |
Where are u buying the kit from. I am thinking of doing the same for my 80 c10. The guy before me ripped all that stuff out.
Posted via Mobile Device |
#18 |
get from vintageair.com, or from summit the link was posted above...
#19 |
I have the same issue and picked up one of these http://www.carid.com/flex-a-lite/ite...Fc07MgodDV8ASg
That's when I decided I am just going to custom build something since there's nothing stealth that's really adaptable to our trucks. I'll post pix when I'm done building it. |
#20 | |
#21 |
If you want to kinda hide the heater hoses a fox body mustang had metal tubes that ran down the side of the intake close to the valve cover.A set of those tubes and make them fit right might work for you.
