04-09-2013, 09:35 AM | #1 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
best carpet sets and who to buy from??
gathering parts for my 72 build, changing the interior color from black to red to give it some sex appeal to it. Who makes the best fitting molded loop carpet sets for these trucks? I have used ACC carpets many times and for the most part have been pleased with final fit but it takes way too much trimming to get them to fit correctly. Is there something better than ACC?? Is there a company that makes carpets that have the sewn edges that are correct fitting, and a direct drop in, no trimming required??
04-09-2013, 10:05 AM | #2 |
Re: best carpet sets and who to buy from??
I bought an ACC carpet through RockAuto last month and didn't have to trim it at all. I just had to cut holes for the shifter and the dimmer switch.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
04-09-2013, 11:02 AM | #3 |
I got mine from Mark at ECE. I don't know what brand it was but it fit very well and just had to cut for the dimmer as well.
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
04-09-2013, 11:23 AM | #4 |
My expierence with the ACC carpets I have installed, probably 5 or 6 different ones in various types of cars and truck but never a 67-72 era chevy, was that each carpet needed trimming along each side, along the front and sometimes in the back on pick-ups. Usually a couple inches on the sides, and 2-4 in the front to get the heel pad placement in the correct location. The fit and finish was overall good and the quaility of the carpet was nice as well, but the extra trimming took lots of time since it was an "ease upon approach" because one wrong cut and and the carpet was JUNK and thats what i want to avoid on this one....since I'm bound to make a mistake sometime!!! Now maybe i was buying the "bargin" ACC carpet because mine typically costed no more than $130. Is there a "priemium" carpet that cost more, but doesnt require trimming??
04-09-2013, 01:10 PM | #5 | |
04-09-2013, 11:37 AM | #6 |
ACC for the Corvette and soon to go into the Longhorn. The Vette install was flawless....
Unbolt seats, sill plates and console Put carpet down Install seats, sill plates and console.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
04-09-2013, 12:49 PM | #7 |
Funny you should ask, just did mine this past weekend. I went with a Trim Parts carpet kit, I bought it from Matts Classic Bowties. It installed very easily and was a perfect fit. I bought the carpet for the tank removed cab, I still have my tank, but planning ahead.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
04-09-2013, 01:14 PM | #8 |
I installed ACC with mass backing in November when it was about 30 degrees. I followed directions and left it unfolded in the house a few days to reduce the fold lines. It installed quite well, and I really would not have had to trim. However, I did cut about 1-1/2" off where it goes under the sill plates to remove the binding along the edge and allow the plates to fit better. I would not have had to do that, but, since that's the way GM did the original, I figured it would be a good idea. Overall, I was very pleased with everything except that the heel pad is not quite in the right place. That's OK though since I'll be using mats.
I found the best price at from Rock Auto and recommend them as well as ACC. Remember, patience and time are your friend when you do this. Nice warm weather is a plus as it would aid the "workability" of the mass backed carpet... if that's what you select. An installation tip I found in a video on one of the carpet websites is to cut the holes using a hole saw IN REVERSE. I have factory buckets and had to cut about 25 holes! I located the hole locations from underneath the truck using an icepick, marked each hole with a white marker, and held the carpet above the floor when cutting the hole. I used either a 3/4" or 1" hole saw. Last edited by FirstOwner69; 04-09-2013 at 01:40 PM. |
04-09-2013, 01:39 PM | #9 | |
I installed seats from a 04 silverado, with a center console from an 09. Luckily I only had about 8 holes to drill, but yeah...I feel your pain. Actually I had 10 holes since I had to cut slits for the seat heaters.
04-09-2013, 01:50 PM | #10 | |
Here's a picture of the carpet with floor mats in place and the original tank carpet. |
04-09-2013, 01:53 PM | #11 |
That looks sharp! I like the buckets, but I have 2 little boys that ride with me occasionally, so that meant the center seat/console was the only way to go. I'm not really the "bench seat" type of guy.
I like the carpeted back panel. As soon as I get rid of ol dynamite in back, I'll start building my compartments/speaker setup behind my seats.
04-09-2013, 02:55 PM | #12 |
subd
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
04-09-2013, 03:23 PM | #13 |
I got one for my 56 from LMC & it is junk.
04-09-2013, 03:27 PM | #14 |
Laid Back
Trim parts best out there!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
04-09-2013, 03:44 PM | #15 |
OK.... you guys are scaring me. I should receive my new carpet from Brothers on Wednesday. Anybody had experience with the kit from them?
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
04-09-2013, 03:48 PM | #16 |
Frequent Flyer
X2
Used Trim Parts Carpet in several 67-72's and been pleased. |
04-09-2013, 03:42 PM | #17 |
Stock interiors. Ordered for high hump with no gas tank thick plush pile with mass backing and finished edges. Took about 5 days to receive not bad for a custom order. Fit perfectly. I also ordered an extra yard of carpet to do the rear interior wall.
Posted via Mobile Device |
04-09-2013, 09:38 PM | #18 | |
04-09-2013, 05:27 PM | #19 |
quote from Trim Parts website: " we leave all carpets long and wide, so the customer can achieve a custom fit to their car. There will be cutting and modification involved in the installation process"
....cutting is what I'm trying to avoid if its available. Sounds like some have had to trim and some do not? |
04-09-2013, 06:15 PM | #20 |
I guess I did miss that part of your original post. I didn't have to trim anything. I haven't put anything back together yet so I went out and took a couple pics.
You can see how close it is to the kick panel, it's a PERFECT fit. The other pic is at the door sill. It lines up perfectly with the edge. I can't say anything about all their products, but the Trim Parts carpet I bought for my Camaros and Chevy Trucks are spot on. I did want to say that no matter who you get your carpet from, you will always have to make holes for things like seats/shifter/high beam switch. There are too many variations for a company to make EVERY version. For this project, I like that it wasn't cut for seat bolts and high beam because I have a 04 seat for my truck, and I'm not using the factory high beam switch.
04-09-2013, 09:00 PM | #21 | |
04-09-2013, 09:48 PM | #22 | |
04-10-2013, 11:42 AM | #23 |
My 67 has original buckets, and had the original carpet in it (or rather what was left of it) and it didn't go all the way under the seats either. I just got my kit, it is Trim Parts, looks great.
04-11-2013, 02:44 PM | #24 |
Great thread! Getting ready to redo my interior. It's nice on these boards to just hear experiences and preferences, rather than endless whining about how things aren't just plug and play.
04-11-2013, 03:16 PM | #25 |
Trim parts has so many styles. I dont know which is good. What did yall get? And I'm assuming that the TURBOHYDROMATIC TRANS means high hump?
Bird |
