View Poll Results: what fluid do you use | |||
type f |
0 | 0% |
dexron |
0 | 0% |
steering fluid |
6 | 75.00% |
other |
2 | 25.00% |
Voters: 8. You may not vote on this poll |
power steering fluid input
What does anyone recommend for power steering fluid.
Type F, dexron, or power steering fluid. I am sick about the headaches of my steering since replacing parts. As a kid, I just put it together and added fluid. This build, I used prestone with all new components, and I still have a whine, Bubbles in the fluid. Today i am going to disassemble, flush and install new o-rings. I am thinking about going with the old tried and true tranny fluid. All input is appreciated. Chris |
![]() Join Date: Oct 2011
Re: power steering fluid input
If i remember right I had to jack up the front and turn wheel back and forth to rid the problems of bubbles and such....when I installed a new pump....
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
#3 | |
I have done that, And i thought it was all good, and not the bubbles are back. It is a long shot, but maybe an o-ring is introducing air into the system. |
At the body shop.
Manual box fixed all of my leaks..
" That didnt make it any newer " " Dont antique the equipment " |
I clicked "other" and then realized dextron is ATF. I just use ATF.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Power steering fluid has additional additives to aid in seal life, is less prone to aeriation and overall is more designed for the cicrumstances to which it operates. ATF is suitable in a pinch but as a rule of thumb, avoided in power steering systems. Try jacking the front end up and moving the wheels lock to lock multiple times with the reservoir full. Do not turn the steering wheel to accomplish the movement of lock to lock. Grab one of the front wheels and physically muscle it lock to lock. This relieves pressure on the control valve and will aid in removal of and trapped air....
