A6 AC Compressor upgrade options
I've been doing quite a bit of research and see I have several options. I obviously want the AC to be cold and work well, but I also don't want to spend unnecessary $$ doing it.
Here are the 3 options I have found and anyone can chime in and tell me if they have done them, or which one would be the best. 1.) Replacement bolt in style compressor that uses OEM brackets. Keeps stock location. $345.00 http://www.oldairproducts.com/catalo...25678606e23d2b 2.) Sanden SD5 kit like this one: $499 http://www.ebay.com/itm/73-76-Chevy-...ce0efa&vxp=mtr 3.) Sanden 508 compressor and Billet Specialties bracket kit. Approx $139 for the billet kit and another $150 for the compressor. http://www.summitracing.com/parts/bs...make/chevrolet http://www.ebay.com/itm/NEW-8390-SAN...3089b0&vxp=mtr The more I keep looking and thinking about it the more i confuse myself. lol |
Moderator
![]() Join Date: Oct 2008
Re: A6 AC Compressor upgrade options
Go serpentine with GM parts (88-98 T400 CK chassis) and use the stock compressor from those trucks with square-T400 hybrid hoses (be sure to get the compressor hoses for the fittings). 96+ will have R134 parts. You get the higher output AD or CS alternator mount in the bargain too.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#3 | |
In my area the junkyard is littered with gmt400's, and it is almost cheaper to buy the whole engine with accessories. Then just the accessories.
I like the TBI version better then the Vortec as it makes valve cover removal easier. |
I am converting my 1974 GMC C1500 to serpentine as part of a complete renovation. Do be careful of the year model you get the parts from. I got mine from a 1999 Suburban and the passenger side bolt holes don't match up. I had to get a bracket made to hold it in place. Also check your heads to see if all the holes for the serpentine bracket are drilled. There are some threads here about drilling them if you have to. Best of luck!
Well, for simplicity reasons I went with the bolt in replacement. Got it locally for $290. It's about 15 lbs lighter than the stock compressor, bolts right in, and is supposed to use less HP, and cool better. Waiting on a ac line to be redone, then I should have cold air!
Here is a pic showing the weight difference. ![]() ![]() Posted via Mobile Device |
#7 | |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
![]() Quote:
Is it a direct fit with GM brackets? Manufacturer & part # for the compressor. Where can I get one? Will it work with all of the factory GM fittings, lines, etc etc? Lastly, will it take 134a ? Sorry for all of the questions but I am relatively close to redoing all of mine. Does anyone else have any input using the aluminum compressor ? Thanx!!!! Posted via Mobile Device
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
I always wondered if you could help your gas mileage by getting a more modern, more efficient AC compressor in place. Say something off a 2011 or a 2012 truck. AC compressors have improved a good bit since the 80s.
Moderator
The old Harrison A6 is built like a tank and uses fuel like one too...
#10 | |
![]() Join Date: Jan 2001
Thanks, Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
#11 | |
Everco A/C A6 Compressor
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper. ![]() |
#12 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Biggest issue is the use of 134 in compressors and systems never designed for it. If at all possible stick with r12. Its much easier on the compressor and cools the best. Uses less fuel to run it. You can hear the differences between the two.
Have yall heard about that new switch big brother wants us to make? IIRC, it was to something called R117... or something. Well its $112 a can lol. Leave it to the gub'ment. Its been a couple years since I heard that on the radio though.
#15 |
Yes, and they are going to tax all older refrigerants to match the price of the new stuff. We may be in for a real screwing.
#16 | |
#17 |
I have no idea what R117 is made up of. All I know is that's what the article I read stated, who knows what will happen? I can only imagine a worst case scenario with our government involved. The article said the new systems would be compatible with the old refrigerants, so the tax hikes are to keep people from putting the older, cheaper stuff in new cars when they need to be repaired.
#18 |
There are two new refrigerants coming out. Dupont of course has the one being pushed here. Its called 1234yf I can't remember the trade name. They claim with small modifications it will work in the 134a systems. VW and Mercedes in Europe is going with co2. Co2 systems need pressures 5-10 times what we use today. I can't imagine what a system operating at 1000-3500 psi is going to look like. Talk about a bomb under the hood. Although not approved for mobile systems I will stick with hydrocarbon if it comes down to paying $100+ per pound for refrigerants to stay cool. I have used them for years and had good luck with them.
