Old 04-09-2013, 07:02 PM   #1
rs74
rs74's Avatar
My frame is cracked.
I tore the whole truck down then had it media blasted and still didn't notice it. I showed up to the paint shop today and the painter said that it had a crack in it. Sure enough. It is in the inside lower lip of the frame back from the power steering box. I think it is an odd spot for it to crack. In the first pic you can see where it is in relation to the steering box. I am going to try to pull it back together and then grind a v in the crack and weld it up then grind it back down.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-09-2013, 07:29 PM   #2
1977cheyenne_C10
1977cheyenne_C10's Avatar
Re: My frame is cracked.
that sucks man. hope everything comes out good
1977cheyenne_C10 is offline   Reply With Quote
Old 04-09-2013, 07:31 PM   #3
rollin thunder
rollin thunder's Avatar
x2. glad you caught it!
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 04-09-2013, 07:57 PM   #4
cmyc5575
What would cause this to crack like this?
cmyc5575 is offline   Reply With Quote
Old 04-09-2013, 08:18 PM   #5
rs74
rs74's Avatar
That is what I want to know. I have had this truck for 15 years and never wrecked it or overly abused it. It has always had the same engine in it since I have owned it. I am wondering if it was there when I bought it years ago. The engine was healthy but nothing to make a frame crack.
Roy
1987 R10 shortie
Old 04-09-2013, 08:16 PM   #6
superwade57
Actually a really common place for these and other generation (newer even) Chevy truck frames to crack. I think its usually behind the steering box around the bolts that holds it on. But believe it or not the steering box puts a ton of stress on the frame.every bump you hit especially while turning. Jars that gear box.
superwade57 is offline   Reply With Quote
Old 04-09-2013, 08:19 PM   #7
rs74
rs74's Avatar
I knew they cracked around the steering box mount bolts but didn't know they would crack that far back. When I tore it down to the frame I even checked around the steer box mount and seen nothing but didn't look there.
Roy
1987 R10 shortie
Old 04-09-2013, 08:25 PM   #8
B Barber
B Barber's Avatar
A healthy motor does wonders to a frame. It takes a lot of mods to beef one up when you get even higher in hp numbers. This is not an odd place for one to crack at all.
V.P. of The American Squarebody Association.
1982 Sierra, 555 BBC, All Billet 700R4, Fab9 with 4.11's, Full 8.5 cert cage, 31x18x20 MT Sportsman S/R's on custom made 20x15 Amer. Racing Hopsters, 4-link with anti-roll bar and dual adj coilovers, Front drag shocks, Custom interior, and quite a bit more.
B Barber is offline   Reply With Quote
Old 04-09-2013, 08:30 PM   #9
cory d
cory d's Avatar
what have other done to fix this? mine was cracked around the box but the previous owner bought the plate from whatever 4x4 company and fixed it. what can you do for this crack?
cory d is offline   Reply With Quote
Old 04-09-2013, 08:35 PM   #10
B Barber
B Barber's Avatar
I would weld it up, then fishplate it, and weld the fishplate solid. My frame has chromoly tubing welded in various places to strengthen this point, but only because of my torque. That would be overkill for your situation.
Old 04-09-2013, 08:38 PM   #11
superwade57
For the crack pictured.... v, weld, box. For steering box bolts... v, weld, grind flat, put a diamond or circle reinforcement patch weld on inside of frame and use old holes as pilots and redrill from outside. The advantage to a circle is even stress distribution on the patch from other stresses such as motor torque. Any point or angle is a stress point a circle has none
Old 04-09-2013, 08:45 PM   #12
LynnJr
I would weld it up and box it in as others have already said.If you have any more trouble it will be outside of the boxed in area.
LynnJr is offline   Reply With Quote
Old 04-09-2013, 09:39 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Big ol fat front tires pay hell on frames and cause cracks too. Back in the day, here in Texas, a whole bunch of guy ran 10 inch wheels and 295 tires on all corners. Many a frame cracked from that.
They drove like crap too but it was all the rage back then.
I was guilty of it too. This was my daily driver for a long time.
Tx Firefighter is offline   Reply With Quote
Old 04-09-2013, 09:49 PM   #14
rs74
rs74's Avatar
Uhh yeah. I am guilty of that too. I had 10" rims with 295-50's all the way around. I didn't drive it a whole lot after putting the tires on before parking it for 7 years. Maybe that is the culprit. Before putting the 295's on it had 255's or 275-60's all the way around on the 10" rims.
Roy
1987 R10 shortie
Old 04-10-2013, 06:03 PM   #15
1977cheyenne_C10
really? i was planning to go 15x10 all around in my truck.
Old 04-10-2013, 02:37 AM   #16
INSIDIOUS '86
INSIDIOUS '86's Avatar
I beat the living cheap out of mine on corners. Think I'm going to go ahead and reinforce mine soon. Glad I'm getting full cert for welding at school
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-10-2013, 01:03 PM   #17
D.FENS
My '86 cracked in almost the same place as yours has. Far as I know it was a stock truck before I got it, so the wide - tire / deep wheel thing may not be the only cause. I had a friend fix it for me, this was before I had access to a welder.
My '78 was repaired by or for a previous owner, they fixed it by welding big flat washers or maybe just flat discs over the steering box bolt holes then re-drilling them.
D.FENS is offline   Reply With Quote
Old 04-10-2013, 04:56 PM   #18
rs74
rs74's Avatar
I was able to pull the frame back together today with a c-clamp. If I get time tomorrow then I will put a tack on it then v out the weld and then weld it up. I will grind it down afterward and maybe put a small fish plate over that. I hate to do the fish plate but that is probably the best thing to do.
Roy
1987 R10 shortie
Old 04-10-2013, 05:21 PM   #19
DREAMER1
DREAMER1's Avatar
May not be any more help than what the other guys have already said, but in industrial steel applications we always drill a hole in front of the crack. In the direction the crack is going. Stress causes the tearing/crack. By drilling a small hole in front of it it will relieve the stress. THEN we cut a gap where the crack is. In your case a deep V would be fine.
DREAMER1 is offline   Reply With Quote
Old 04-10-2013, 05:59 PM   #20
xole
xole's Avatar
Here is the brace kit OffRoadDesigns.
I was thinking of doing this on mine.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
