View Poll Results: What direction to head next | |||
Idle Circut | 2 | 20.00% | |
Vacuum Leak | 1 | 10.00% | |
Ignition/Timing | 3 | 30.00% | |
Junk the Eddy | 4 | 40.00% | |
Multiple Choice Poll. Voters: 10. You may not vote on this poll |
04-09-2013, 09:16 PM | #1 |
Hello all
I am new to the forums and this is my first post, so bear with me and guide me where I need to go. I have a 1986 C10 with a modified 305, from what I know it has
601 heads I Think .204/.214-.420/.443 cam 112 lobe SA performer intake stock Edelbrock 1406 electric choke. I have searched all over with no luck. The issue I am having is today out of the blue, I feel like I am getting a miss on one cylinder only at idle. All plugs are firing,tested for vacuum leaks, Nada! Here is the kicker I turn the the idle mixture screw on the Right, engine stalls(Normal)... Turn the one on the Left, and the idle increases when turned clockwise, decreases and stalls counter clockwise. I am leaning towards a blocked idle mixture bleed tube/circuit (as it is the next cheapest thing to check but need shop air to blast it clean) Thanks, Look forward to many more head scratching moments with yall.... |
04-09-2013, 10:27 PM | #2 |
Re: Hello all
I would try cleaning the carb out. On my eddy at idle it ran so rough I thought it was a miss. took it apart cleaned it all out and put it back together worked like a charm! This is from my experience (i am by no means a carb expert) definitely check all vacuum lines. make sure not cracked or torn and if the wrong kind of hose is on there sometimes it could collapse. Ive only seen it once.
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
04-09-2013, 10:37 PM | #3 |
Re: Hello all
Thanks thunder, I will try and rebuild it this weekend if it continues. All the lines are new/reinforced hoses, learned that the hard way with the egr and vacuum advance lines, they were so thin that the collapsed .
04-09-2013, 11:12 PM | #4 |
Re: Hello all
no problem hope it helps and you get it figured out. and you should throw up some pictures of the truck when you get a chance
04-10-2013, 01:03 PM | #5 |
Update**
Well it was partially a clogged idle circuit system (I can adjust the Idle mixture screws)... Blew it out with compressed air, fired it up and ran great.....then the miss came back.... Changed the fuel filter for a clear one as a new filter was my last hope and the gas is milky colored and after sitting has water floating in it...Bad gas from a new gas station that just opened up.... good thing I only have a quarter of a tank
04-10-2013, 08:44 PM | #6 |
Re: Hello all
glad you got the culprit! good straight looking truck and pretty engine!
04-11-2013, 08:31 AM | #7 |
Re: Hello all
Is this a Blower Drive Pulley I see?
Desert |
04-11-2013, 04:43 PM | #8 |
Re: Hello all
@ Desert1957 It is a gilmer belt drive made by procomp.
As for my truck I have fresh gas, and the miss at idle is gone but when warm and driving down the road anytime I get around 1500-1700 it acts like it has a miss but you hear no change in the exhaust note.... It feels like this: vroooooommmmmmmm..uga(fraction of a second)...vrooooommmmmmm.uga-uga....vrooooommmmm...once over 1700 It goes away, Buddy of mine says its a lean surge, why would it only do it in that rpm range? I am breaking down the carb and rebuilding it tomorrow... my only guess is whatever clogged the air bleeds may have clogged one of the air bleeds in the primaries this in turn gives enough fuel for idle?!..but not part throttle Once I find the dang Gremlin that lives in my truck...Im taping him to the belt and letting the fan take care of the rest of him @ 5000 rpm Last edited by Montync; 04-11-2013 at 04:44 PM. Reason: Missspell |
04-11-2013, 05:38 PM | #9 | |
Re: Hello all
04-12-2013, 05:08 PM | #10 |
Re: Hello all
Well the carburetor was dirty..I am surprised it even ran at all. *some yahoo forgot to put a filter for the needle seat on at the factory, combined with a faulty filter make a heck of a mess. my float measured 13/16 inverted and the float drop was past an 1 inch and a half. I rebuilt it and I have to find a vacuum gauge to readjust my setting, plus the gas gave me a massive headache..... I will test drive it tomorrow.... and post an update
Once I find the dang Gremlin that lives in my truck...Im taping him to the belt and letting the fan take care of the rest of him @ 5000 rpm |
