04-12-2013, 10:32 AM | #1 |
C30 Dually Lugs for 16" Alcoa Rims
I just picked up a 1981 Chevy C30. I have a set of 16" Alcoa wheels to put on it. I have found some Gorilla lug nuts, but they darn things are $9 each. I need 9/16"-18 lug nuts with a 0.50" shank. Any other sources out there?
04-12-2013, 10:54 AM | #2 |
Re: C30 Dually Lugs for 16" Alcoa Rims
I got some at Auto Zone which is a parts supplier out here for $2.50 each.
You could try Rock Auto, your local parts guys, and scrounge a set in the local pick a part. They charge about 50cents a bolt here. |
04-12-2013, 11:08 PM | #3 |
I think you can use factory lug nuts from a 1980 to mid 90s ford f350 dually
They have the correct thread and are a swivel flange type nut that works on alcoas Should be at any light truck junkyard (recycle center in todays listings) |
04-17-2013, 03:02 PM | #4 |
Thanks guys. I found some a lot cheaper than the ones I was first looking at.
05-21-2013, 10:40 AM | #5 |
Found the lug nuts and got the Alcoa's on... thanks for the help
05-21-2013, 11:09 AM | #6 |
Nice, Now I want to ditch my simulators. Only been on the truck 2 weeks....
Desert |
