04-13-2013, 11:10 PM | #1 |
Six lug rear end options on TF?
I've got the stock rear end in there at the moment. Putting a 4.8 liter LS motor + 4L60E in, planning to drive it a lot and want to keep six lug pattern.
Are the stock rear ends any good? I'm skeptical that it will hold up, dunno why. Will a C10 12 bolt work, or will the wheels stick outside the fender line? |
04-13-2013, 11:51 PM | #2 |
Re: Six lug rear end options on TF?
67,68 and 69 c10 and K10 1/2 tons both had 6 lug and WMS (wheel mount surface) is 62 1/2 with the same 1310 u joint that yours has.
Posted via Mobile Device |
04-14-2013, 12:06 PM | #3 |
^^ aren't those all open spool one wheel wonders.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-14-2013, 10:58 PM | #4 |
Not all of them. here in the sierra foothills lockers and limited slips are about 50% the ones I have seen. Mostly limited slips
04-15-2013, 03:12 PM | #5 |
Anyone ever try an AWD Astro van rear axle? those are 6 lug.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
04-14-2013, 04:50 PM | #6 |
You could put a V8 Toyota truck rear under it- same bolt pattern and (I think) same width.
04-15-2013, 03:37 PM | #7 |
You can change bolt patterns on most axles if they have the room.
http://www.dutchmanaxles.com/services Posted via Mobile Device |
04-15-2013, 08:57 PM | #8 |
I think the Astro uses a different pattern, like 6 on 5 or something silly.
I'll keep an eye out for those C / K10 axles. The Toyota might get used, but while I'm on a roll with keeping it Chevy I think I'll try and continue the trend. |
04-16-2013, 09:32 AM | #9 |
04-16-2013, 09:52 AM | #10 |
How did the width on that 68 compare to the original axle?
04-16-2013, 11:35 AM | #11 |
IIRC, they were the same at 61"
