06-21-2003, 04:36 PM | #1 |
Fan Shroud ?
I'm Running a 275 Hp 327 ,4 core Rad. Should I run a fixed fan or a 20" with a fan clutch , & what Shroud will work with a 20" Fan on our trucks ?
06-21-2003, 04:43 PM | #2 |
20' Daredevil (Ret)
Can't advise on the shroud, but IMO use a clutch fan! A fixed fan will always be noisy and rob power. I once temporarily used a flex fan and it didn't cool well at all.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-21-2003, 05:20 PM | #3 |
Inline 69
06-22-2003, 12:11 AM | #4 |
its all about the +6 inches
Not to mentione the flax fans giving out and shooting a blade through the hood and any one's head that might be looking over the engine at that particular time.
While I have never heard of anyone being killed, and I admit it may well be an urban legond, I have seen first hand when the blades come free and cut right through the hood and brace. Not pretty. (even GM had a re-call on the stock flex fans) A clutch with a fixed blade fan is the only way to go. Don't need to upgrade anything, just good condition stock items should cool your engine. I don't even have a Shroud on mine, and I have no problem cooling it. |
06-22-2003, 08:41 AM | #5 |
Guy here in Wichita died about 2 years ago - confirmed on the news. Pretty scary, used to have one years ago. One of the vendors posted some info a while back on the different stock shrouds so hopefully they will see your post and get that info to you. I was kind of thinking about building one out of aluminum, could be a good option if done right.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-22-2003, 11:25 AM | #6 |
I'm runnig an alluminum flex fan with no problems but I'm looking at going stainless just to be safe. I got my shroud out of an 80's van and it bolted right in.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
06-22-2003, 11:37 AM | #7 |
Hmmm, a van shroud, never thought of that. Your combo includes a small block with a short, or long pump?
06-22-2003, 11:54 AM | #8 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Whats a flex fan look like cause my shroud definitely looks as tho a blade came flying off to bust the thing up...
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
06-22-2003, 01:46 PM | #9 | |
20' Daredevil (Ret)
06-22-2003, 08:43 PM | #10 |
Found a Shroud to work off of a 69 Gmc 305 , had to drill new holes 3/8" Higher , It fit & looks Great . Thanks for your input Paul
06-23-2003, 06:26 AM | #11 |
shroud
i missed a shift once and a blade let go and went right thru the hood. The watewr pump then broke off and went thru the radiator. At least if there had been a shroud there, the hood would,ve been saved.........Zoomy
06-23-2003, 05:55 PM | #12 |
A flimsey little shroud isn't gonna save anything with a flex fan exploding at 6500 RPM...nothing but distance and time will stop it if it makes it through the hood and brace.
