Old 04-16-2013, 03:05 PM   #1
usnabill
usnabill's Avatar
Matching a bellhousing to my transmission
Hello,
I have a 4.1L 250 in my C10 and a newly rebuilt Saginaw 3 speed. My current bellhousing won't fit the ring on the transmission (bellhousing opening is too small). I am having trouble figuring out what bellhousing I need to complete this project. I have the smaller 10 inch clutch installed right now, but all the bellhousings on ebay with the large opening are for 4 speeds. What gives?
usnabill is offline   Reply With Quote
Old 04-16-2013, 03:40 PM   #2
par4tom
Re: Matching a bellhousing to my transmission
Do you have a pic? Sounds like the retainer is too large?
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 04-16-2013, 03:42 PM   #3
usnabill
usnabill's Avatar
The retainer is definitely too large. Do truck transmissions use a larger retainer than car transmissions? I may have a bellhousing intended for a car.
Old 04-16-2013, 03:46 PM   #4
par4tom
I couldn't answer that for sure...but I just did an NP440 swap and took the bearing retainer to the machine shop and they machined it down to fit the 4 11/16 opening in my bellhousing.
I would guess your bearing retainer is probably just over 5 inches. Pretty easy fix...look up Music Man's threads...he know a lot about these and has some really cool photos of before and after.
My Build Thread
Old 04-17-2013, 12:39 AM   #5
Captainfab
60-66 Nut
The bellhousingf '67 and earlier had the 4-13/16" center bore. The bellhousings '68 and later had the 5-1/8" center bore. It sounds like you have a '68 and later 3 speed Saginaw. All you need is a '68 and later truck bellhousing with a 5-1/8" center bore. It does not matter if the original trans bolted to the bellhousing was a SM420 4 speed....the bolt pattern is the same as your Saginaw 3 speed.
