polyplus bushings
Should I use polyplus or rubber bushings for my trailing arms? I have heard that rubber might be better for better articulation.
Re: polyplus bushings
Ive heard better talk about the rubber personally. Heard the poly's have to be replaced more and squeak more.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
The trailing arms rely on the bushings to "give" to let the axle articulate without binding. Rubber is better, but if you want/need less bushing deflection then you'll want to build tubular arms with heim-style bearings to let the arms rotate smoothly without binding.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
