Old 04-17-2013, 08:48 PM   #1
wildfifty2
Replacing rear window on 1952 1/2 ton
I have purchased a new peice of glass as well as the seal for the rear of my 1952 Chevy truck. I have read several threads regarding replacing this window but none of them state if a sealer is used on the seal or not? The new seal comes with the chrome bead lock, is this enough or should i be setting it with some 3M sealant? Thanks in advance..
wildfifty2 is offline   Reply With Quote
Old 04-17-2013, 09:33 PM   #2
focusedontheprize
focusedontheprize's Avatar
Re: Replacing rear window on 1952 1/2 ton
I put mine in two weekends ago.
I soaped up the seal and installed it, then worked the glass in with a body filler squeege. Once it was in, I went inside the cab and put that bead lock in. After it was all said and done, it fit incredibly snug, but I still will run a light sealer around it just to give me a little insurance. I will be doing this with the front glass too.
focusedontheprize is offline   Reply With Quote
Old 04-17-2013, 09:52 PM   #3
wildfifty2
Thanks for the input... I have changed many door and wing windows but this will be a first for this type of glass install. It seems to be very straight forward. Just like every other project.. the remove and replace is smallest part of the job.. I cant take anything apart with out cleaning sanding and painting which makes the job a week long project.
Old 04-17-2013, 11:39 PM   #4
mknittle
mknittle's Avatar
That's a good thing
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-17-2013, 11:55 PM   #5
focusedontheprize
No argument here. I cleaned everything up and POR'd the jams. Why put new stuff on old rusty stuff?
Good luck.
Old 04-18-2013, 02:01 AM   #6
msaintg
msaintg's Avatar
Inside the cab? When I did my back window, the instructions said to put the rubber on the glass and then use a rope to pull the rubber onto the cab frame.... which is what I did. I thought the bead lock went on the OUTSIDE. Did I screw up? Oh, I didn't use any sealant either. I don't think this kind of seal was ever intended to have sealant put on them back in the day. Mike
msaintg is offline   Reply With Quote
Old 04-18-2013, 03:20 PM   #7
focusedontheprize
Nope no screw up at all mate. Like Marc said and I did the same thing - I wanted a smoother look on the outside of mine window. Inside, I used the black bead lock so it really wasn't going to be that noticeable inside the cab.
You can do it without sealer too, like I mentioned in my first post, it gives me extra insurance on the leaks. I have a cross country trip coming up soon and I am not interested in having leaks.
Old 12-03-2016, 03:10 PM   #8
57chevy3100
Hey guys!
I just finished the 57 3100 vent and door windows, now ready to tackle the front and rear.
I am sure I can do it, but are there any "special" tools I will need to do this?
57chevy3100 is offline   Reply With Quote
Old 04-18-2013, 12:37 AM   #9
mr48chev
mr48chev's Avatar
I've had mine in an out several times over the past 30 years and never put any sealer on it and have never had a leak except where the rubber shrank and the gap between the ends widened up. To clarify I used bulk window rubber from the local glass shop. The same stuff they use on a lot of farm equipment and heavy equipment.
My ongoing truck projects:
Old 04-18-2013, 06:53 AM   #10
coralhead
coralhead's Avatar
Never seen one installed backwards but it can happen. The beadlocks go on the outside of the truck
coralhead is offline   Reply With Quote
Old 04-18-2013, 12:03 PM   #11
youngrodder
youngrodder's Avatar
I mounted mine with the lock bead on the inside of the cab beause I wanted a soomther look to the outside of the cab. I didn't see where it would really matter unless you were going for a 100% accurate restoration. I was not.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-18-2013, 03:18 PM   #12
focusedontheprize
Marc
Exactly why I did mine that way.
Old 12-03-2016, 08:29 PM   #13
MARTINSR
MARTINSR's Avatar
Here is a few great tools that are MUST in opinion.
http://www.hotrodders.com/forum/wind...ls-360386.html
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
