Incomplete air ride?
Hi guys, I recently have purchased a project and I'm trying to find out all the missing pieces.
It has bags installed on all 4 corners and airlines are run to them. Here are the pictures. Pleas help me find out what I am missing. Thanks John Posted via Mobile Device Posted via Mobile Device |
Re: Incomplete air ride?
Another
Last one
Please, any help would be greatly appreciated!
That looks like a tiny compressor!
You'll need airline run from the compressor to the tank. A check valve between compressor and tank. Airline from tank to valves. Airline from valves to bags. And all the fittings that coincide. Then a keyed relayed power source to power the compressor. Airline routing. ![]()
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp Last edited by maxxxy; 04-19-2013 at 02:13 AM. |
Can you tell me what the 3 things that the arrows are pointing to?
thanks |
From top to bottom, guages, switches, manifold. It just so happens that all three of those are combined in your setup. So that part of the picture is irrelevant to you.
So on yours you'll have one airline going from the compressor to the switches, and 4 coming out of the switches, one to each bag. Posted via Mobile Device
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
Sweet, thanks for the explanation.
one more thing, is there a place that I can buy the check valve and fittings from a local store? Or do I have to buy online? thanks |
Most likely it'll be cheaper online. Check our suspension vendors. They usually have deals for forum members. There might be a few places locally as well if you'd prefer to go that route. Most of the local fittings and airline I get, are from big rig accessory shops like Fleet Pride, or something similar.
Where is a good location to mount the tank and compressor ?
You can mount them just about anywhere you got room,From in the bed to the outside of the frame rails under the bed or even under the rear of the bed
