04-19-2013, 02:17 PM | #1 |
Tie rod boots
On the way home from LSRU in Austin I noticed a strange squeak in my front suspension. When I got home and got it in the air I found both outer tie rod boots were torn. How does that happen? I rebuilt the front end about 2 years ago and probably don't have 10-15k since then. I didn't use the highest quality parts so i'm wondering if it is just cheap stuff or is there another cause. Thanks for any input.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
04-19-2013, 02:32 PM | #2 |
67-72 parts collector,…
Re: Tie rod boots
You can buy just the boots from Energy Suspension,... unless you plan on changing out the tie rods again.
04-19-2013, 03:27 PM | #3 |
Re: Tie rod boots
Thanks for the suggestion, I ordered them last night from Summit. I'm just trying to figure out the cause. Or maybe it's my fault for buying cheap parts to begin with.
04-19-2013, 06:23 PM | #4 |
Re: Tie rod boots
Chinese rubber products maybe?
I would inspect your tie rods closely when you replace the boots.
