Old 06-22-2003, 02:11 AM   #1
orange72350
orange72350's Avatar
Cant Figure Out What This Stupid Wire Is For!!!
I recentley yanked out my stock 350 to swap with a re-built. im trying to sort out wiring in the engine bay. it was a rats nest from the last guy. Theres a black wire, with a cap on the end of it. The inside of the cap has a female spade connector in it. it runs in the same group of wires as my yellow for my ignition, and my two starter wires. its not a tach, and it isnt real long. I figure its gotta be a sending unit of some sort, but i cant figure out what its for. I dont remember taking it off the old motor, but its not full of oil and road crud, so it was obviosly hooked up recentley. Could somebody please bail me out before i just cut it off and realize later that i made a mistake!! Thankx for all yer help
Dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 06-22-2003, 03:57 AM   #2
Als454
I don't have my truck here right now so I can't check. It doesn't go to the heater blower motor does it?
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 06-22-2003, 04:11 AM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
look where it goes thru the firewall, and look in a Haynes manual to see what it is for.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 06-22-2003, 07:04 AM   #4
blue_69
someday
blue_69's Avatar
sounds like the reverse light switch wire that would plug into a switch on the tranny. On a 4 speed its on the top just foward of the shifter dont remember what side though.
jason
Click Here to search ebay for all 67-72 parts
My 72 CST blazer build
72 CST Blazer 4x4
67 2wd swb ( project onion crate )
86 4x4 lwb plow truck
40 x 60 foot barn to work on all this stuff
blue_69 is offline   Reply With Quote
Old 06-22-2003, 07:39 AM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
if you have an auto it is the TSC presure switch harness. On the right side of your tran towards the top you will see it with 1 spade terminal. It lets the emissions equipment function when the tranny is in 3rd gear.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-23-2003, 01:07 AM   #6
orange72350
i dont think it goes to the tranny. it goes back through the firewall, and isnt very long. i dont wanna trace the harness 2 see what its for, but i dunno.
Old 06-23-2003, 02:09 AM   #7
alta-aj
How about the temp sending unit?
AS above.
alta-aj is offline   Reply With Quote
Old 06-23-2003, 02:38 AM   #8
jef5150
Inline 69
jef5150's Avatar
i think da-burb is correct,my wiring diagram shows black wire,(auto) for "asm TCS switch"
jef5150 is offline   Reply With Quote
