Old 04-22-2013, 09:41 AM   #1
MrMilks
MrMilks's Avatar
Clearence Question
So I have an 85 Short wheel base and I'm wanting to do a 2/4 drop with some 20x8.5 rims. My question is will 255/45/20 tires work and clear the wheel arch when turning?
MrMilks is offline   Reply With Quote
Old 04-22-2013, 11:50 AM   #2
stroker87
Re: Clearence Question
the tire size should not be a problem that size is a little over 29" its the offset of the rim i think that your going to have to worry about but on mine with the 2/4 drop the factory tire size 28" tall tire with a 4" back space of the factory rallies tires clears every thing with a ton of room (the 15" rim though will not work any more hits the lower control arm)
i'm sure one one with a little more knowledge with chime in
stroker87 is offline   Reply With Quote
Old 04-22-2013, 12:47 PM   #3
J Knight
J Knight's Avatar
WARNING
There is a 98% chance you will want to go lower than 2/4in within one years time.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-22-2013, 12:50 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Originally Posted by J Knight View Post
WARNING
and after lowering to 5/7 you will want air bags...pssst pssst LOL
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-22-2013, 02:36 PM   #5
MrMilks
MrMilks's Avatar
I just looked and the offset is 0mm and to be honest idk what offset is. If someone could explain I'd appriciate it.
Old 04-22-2013, 04:06 PM   #6
MrMilks
MrMilks's Avatar
Is it good to have more backspace or less?
Old 04-22-2013, 07:06 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
Zero offset on 20x8.5 should be fine
1991 GMC Jimmy 4x4
Old 04-22-2013, 09:59 PM   #8
MrMilks
MrMilks's Avatar
Thanks man!
