Old 04-22-2013, 06:42 PM   #1
andyd00
What kind of bolts are these?
Replacing a broken window regulator and came across these bolts.
I have never seen a bit like those before, so I'd thought I'd ask if a slotted screwdriver will work fine. I'v stripped and snapped enough bolts and screws on this truck already and my easy out kit is earning its keep...
If there is a bit for it, does anyone know what they are called so I can order one?
andyd00 is offline   Reply With Quote
Old 04-22-2013, 06:46 PM   #2
Kim57
Kim57's Avatar
Re: What kind of bolts are these?
They are clutch head screws. I used a flat head screw driver to remove the ones on my project. I would hit them with penetrating oil and try that. If it doesn't work you can always buy some that fit.
Not my ad.
http://www.ebay.com/itm/chevrolet-21...-/110654961011
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-22-2013, 07:12 PM   #3
andyd00
Wow that was fast. Thank you so much. The eBay listing you found is actually the cheapest I can find so far too. Amazon wants 6 bucks a piece....
Old 04-22-2013, 09:27 PM   #4
BLUE49
I bought a set of them at my local NAPA store. Its been about 8 yrs ago so I don't remember what I paid.
BLUE49 is offline   Reply With Quote
Old 04-22-2013, 10:01 PM   #5
mknittle
mknittle's Avatar
When they are really stubborn I have used a small pair of vice grips to help the clutch head driver. I replace the clutch heads with stainless button socket head cap screws.
lol Blue I was in fair Oaks this afternoon.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-23-2013, 12:13 AM   #6
Henry50
Henry50's Avatar
I have found them at Harbor Freight before.
Henry50 is offline   Reply With Quote
Old 04-23-2013, 12:45 AM   #7
mr48chev
mr48chev's Avatar
Sometimes you can pick them up at Ace hardware too and they often show up in those XXX screw driver bits in a box collections.
My ongoing truck projects:
Old 04-23-2013, 04:42 AM   #8
Dodger
So far I have managed to get all the ones I've tried with a screwdriver. I was thinking if I strike a stubborn one, an impact driver might do the trick.
I have to replace just the window winder shaft section, not the whole mechanism.
Is that what you are doing?
Any pics you might be able to post of this task would be greatly appreciated.
Cheers.
Dodger is offline   Reply With Quote
Old 04-23-2013, 06:38 AM   #9
coralhead
coralhead's Avatar
I have been replacing mine with Button Head socket head cap screws. I did buy the clutch head bolts for my bed fenders.
coralhead is offline   Reply With Quote
Old 04-23-2013, 09:12 AM   #10
mknittle
mknittle's Avatar
I like that idea.
Mark
My GMC build.
Old 04-23-2013, 09:10 AM   #11
mknittle
mknittle's Avatar
Cheers.
if you mean the impact driver you hit with a hammer that could bend the door and an air one can strip the head or twist off.
Mark
My GMC build.
Old 04-23-2013, 11:49 AM   #12
andyd00
Cheers.
Yes the shaft free spins, which is why I'm doing this. I was just gonna replace everything while I was in there.
Old 04-23-2013, 12:19 PM   #13
62lwbc10
Those old clutch head bolts can be a real pain in the you know what, especially if they are original and never have been touched. I have had to resort to using a cut off wheel to create a deep slot so I can use a flat screwdriver to remove more than once....
62lwbc10 is offline   Reply With Quote
Old 04-23-2013, 07:31 PM   #14
andyd00
Sounds like my kind of luck...
Old 04-23-2013, 11:04 AM   #15
Dodger
The impact driver is just a suggestion in general terms and in relation to those particular bolts which I assume you know appear in more places (some in very solid areas) than just the door panel.
Clearly a suggestion your not keen on mate but one that some may find helpful.
Old 04-23-2013, 09:22 PM   #16
mknittle
mknittle's Avatar
Just trying to avert a possible disaster I have seen people make more work for themselves Too often
Mark
My GMC build.
Old 04-23-2013, 11:08 PM   #17
andyd00
I ordered the bits. Won't hurt to have in case there are other screws like those hidden in the truck.
