Old 04-23-2013, 07:18 PM   #1
71sixgun
Rear control arms; aftermarket vs. GM
Hey guys, I need opinions on this one. Im in the process of a restore on my 71 C10. I need new rear arms, as there is more of mine missing than is there!! I've found some factory ones from a 60-66 on ebay, which I've heard will work. I've also seen the new replacements in LMC and a few others. What is my best bet, new aftermarket or old factory?
71sixgun is offline   Reply With Quote
Old 04-23-2013, 08:35 PM   #2
Andy4639
Old member
Andy4639's Avatar
Cool Re: Rear control arms; aftermarket vs. GM
New is always better. LMC, CPP there are several compainies who build them.
I like Early classic's arms and plan to buy a set sometime when mine are done.
http://www.earlyclassic.com/catalog....railing%20arms
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-23-2013, 08:43 PM   #3
Lee H
Lee H's Avatar
I guess it all depends on what you want and what you are doing with you truck, and how much your willing to spend. Short of full blown racing or off roading the stock arms can handle just about any thing you can throw at them.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-23-2013, 09:15 PM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I would get a used set of 67-72 and have them blasted then paint them. That is a lot of coin to spend for aftermarket when those funds can go for something else.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-23-2013, 09:28 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I'd go with a nice set of OEMs. IIRC the 3/4 ton OEM trailing arms have a reinforcement plate welded to them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-23-2013, 09:55 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Are you truly restoring the truck? If so... OEM.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-23-2013, 11:53 PM   #7
weever82
weever82's Avatar
I went with a set of ECE trailing arms when they were on sale and are amazing! The quality is top notch and the guys over there were great with answering all my questions.
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 04-24-2013, 04:12 PM   #8
71sixgun
I do like the looks of the ECE one's. They price on them isn't as bad as LMC, and they include a bunch of hardware. I guess unless I can find some nice factory ones, I may have to go the ECE route. Nothing about any of the aftermarket ones are cheap though!! Thanks guys!
Old 04-24-2013, 04:28 PM   #9
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I to have the ECE set, with the BB up front and Detroit Locker in the rear it made it stronger and a bit stiffer for sway. I have Lots of ECE stuff on my Truck i.e. springs, shock relocate’s, Center support and trailing arms and its ALL Nice Top Quality stuff
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
