04-23-2013, 09:17 PM | #1 |
'71 SWB frame under a '65?
Hey guys, I am wondering- what would it take to bolt a 65 body onto a good 71 C10 2wd frame that I have? I redid the brakes and would like to utilize the suspension and running gear on my 65 and cut down the bed to make a 65 2wd shortbed, and instead of cutting the frame and bed and bolting all the suspension stuff to my 65 frame... would the body swap be easier? I also have some sweet centerline wheels for the 5x5 pattern. Thanks in advance for any and all help guys, I appreciate it and love the site.
04-24-2013, 07:58 AM | #2 |
Re: '71 SWB frame under a '65?
I know the front frame is different from the steering box forward and the back cab mounts are wrong for a 60-66 truck. You would have to cut your frame and put on the '71 and put your rear cab mounts on it as well. There may be other small differences but those two are for sure different.
04-24-2013, 12:53 PM | #3 | |
04-24-2013, 02:07 PM | #4 |
I have a 1972 long bed frame i have been working on and was wondering basically the same thing. 63-65 body on my frame. Anyone have pics or links to threads.
Vortech thanks fro starting this thread was just getting ready too Thanks Rob Last edited by Fattback; 04-25-2013 at 09:45 AM. |
04-25-2013, 09:47 AM | #5 |
Surely someone has done this before?
Any help would be greatly appreciated. Rob |
04-25-2013, 10:32 AM | #6 |
a lot easier to just put the axles under your orig frame. you also have no hassles with your ser #
ron |
04-25-2013, 06:30 PM | #7 |
Core support mounts @ diff height & fore/aft location (close, but different).
Frame rails diff shape/height @ front bumper. Rear cab mounts higher for pre-67 cabs (spacer could be made to compensate). Some bed bolt holes are different.
04-26-2013, 08:19 AM | #8 |
I am in the process of putting everything from a 71 under my 66; keeping original frame and bolting everything on...
check out my build thread/ elbow deep in my 66.... WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC |
