Old 04-24-2013, 03:21 PM   #1
Low87
been here longer than Liz
Low87's Avatar
steering overhaul
I've needed to replace my gear box for a while now, just added fluid for the time being. I put in a cheap PS pump last year to get me by when that went out. Today the PS pump pulley started squealing. I'm hoping to make it to the weekend before I have to do anything.
As far as parts & what to do, I'm looking for recommendations. Here's what I plan/hope to replace;
gear box
PS pump
PS pulley
rag joint (same as coupling?)
PS lines if I can find them
Any parts recommendations would be appreciated. I'll order from rockauto if I can get them here in time, if not I'll hit O'Reilly's. Other than the pump, I haven't dug into this stuff before. How difficult is the box & coupling?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-24-2013, 03:29 PM   #2
Jonboy
Slots go on anything!
Re: steering overhaul
It should all be pretty easy, Greg. You may need a pitman arm puller for the box, but the rest is bolt on stuff. If it is on the Blazer, all local stuff should be fine. On the '87, you might look into a faster ratio box. I have heard good stuff about Redhead boxes, for a custom one. The rag joint is held to the box with a through bolt. P/S hoses should be able to be had locally as well, the pressure hose being formed and the return being plain hose.
Jonboy is offline   Reply With Quote
Old 04-24-2013, 03:51 PM   #3
Low87
Low87's Avatar
Thanks Jon, yeah it's on the 89.
Okay for a few hour job, or am I looking at a full day?
BTW, congrats on 5grand!
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-24-2013, 07:02 PM   #4
Jonboy
If you look at it as a few hours, it will take all day. Honestly, it shouldn't be too bad, especially with everything new going back on.
5K posts only took 10 years. Good thing I don't have much to say.....
Old 04-25-2013, 10:06 AM   #5
Low87
Low87's Avatar
LOL, I've got less than half your with an extra 3 years to work on it. I suppose I'm guilty of taking multi-year breaks from the site a couple times though.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-26-2013, 10:24 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
does the 89 jimmy have the cooler under the rad like some burbs?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
