04-25-2013, 03:42 PM | #1 |
57 rear boxing plates
Any advice or anything to look out for when boxing rear frame on my 57 ?
Links templates or is it cheaper to buy a kit i am running a no limit rear 4link with airbags ? Bout to work on that this weekend wanna make sure i dont have any surprises Should i notch it or not ? Posted via Mobile Device |
04-25-2013, 03:51 PM | #2 |
Re: 57 rear boxing plates
I boxed mine in and then cut the c notch. It was all done with 3/16" plate and a piece of rolled 3/16" plate for the arch in the notch. It's not difficult at all, just takes time
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
04-25-2013, 03:53 PM | #3 |
What did u cut with i dont want to make a bad decision ?
04-25-2013, 04:00 PM | #4 |
I used my 4 1/2" grinder with a zip cut disc. I used it to cut the traced out shape of my frame and to cut the hole for the notch
04-25-2013, 04:26 PM | #5 |
Are the plates supposed to fit inside or ouside of the frame rail ?
04-25-2013, 05:17 PM | #6 |
unless you can flip your frame or like welding overhead for hours at a time i'd cut it to fit inside the frame
that way you can sit on a bucket and weld the top and bottom flanges i had the metal warehouse cut all my plate to fit inside and trimmed what i needed over the rear axle and where it tapers on the front horns i removed and fabbed up some x-members and kept some in place and notched around them if you don't c-notch your frame the lowest you can is about 5'' and the lowest you'll be able to ride is about 8'' i have a 3-4'' notch, standard bed height and am static at 5'' but occasionally hit the bump stops i would suggest a 5'' notch minimum, more if you don't mind raising the bed more
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
