04-26-2013, 04:43 PM | #1 |
From brake help please
I just put a master cylinder front calipers and pad on my 1977 c10 and I am getting pressure to the proportioning valve and not get any fluid to the calipers them selves what could this be
Posted via Mobile Device |
04-26-2013, 09:15 PM | #2 |
Re: From brake help please
Did you bench bleed your master cylinder?
If you did have you tried opening your bleed screws and let gravity kick in? Sounds like you got air in your lines. Posted via Mobile Device
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
04-26-2013, 09:40 PM | #3 |
The prop valve shuttle valve may have moved, closing the front circuit. Is the brake light warning light on? Crack open a front and rear bleeder at the same time, bleed and then go back to normal bleeding procedure, that usually re-centers the shuttle valve.
04-27-2013, 04:09 PM | #4 |
Re: Front brake help please
no the brake light is not on. I did bench bleed the master cylinder. I will try do the open a front and rear bleeder to reset the valve. if I was to replace the valve should I get a stock one or a adjustable one
