04-28-2013, 03:19 PM | #1 |
1960 C10 rear end swap
So as I am swapping in a front end from a 1979 chevy truck, I want to swap the rear end. I have a rear end out of a 1971 chevy truck, my only question is what panhard bar do I get? And will it just mate up to the original mounting place on the frame? I know they are different from the newer models and was not sure.
Posted via Mobile Device Last edited by Thiessen1960; 04-28-2013 at 03:32 PM. Reason: printed something wrong |
04-28-2013, 03:32 PM | #2 |
Re: 1960 C10 rear end swap
Sorry it is actually the rear Panhard bar that I am looking for to perform this swap correctly.
04-28-2013, 09:47 PM | #3 |
Cut the original panhard mout bracket off your original rear (note locatioin) and weld it on the 71 rear. Bolt up the original panhard... done.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4 |
04-29-2013, 06:59 AM | #4 |
Check... that is the way I did mine as well back in the day. Worked perfect.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
04-30-2013, 02:31 AM | #5 | |
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
04-28-2013, 11:16 PM | #6 |
The newer rear end has a mounting location for the panhard bar and I'm not much for welding.
Posted via Mobile Device |
04-29-2013, 12:05 AM | #7 |
I just need to know what bar I can buy that will mount up.
04-30-2013, 06:07 AM | #8 |
Thanks everyone. I had a friend weld the mount on the new rear end and it bolted in perfectly.
04-30-2013, 07:10 PM | #9 |
Good to hear any pics of it ? How did the u bolt saddles come out?
I was going to recomend a bolt on bar but looks like you solved it !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
04-30-2013, 07:18 PM | #10 |
No I don't have any pictures of it. The new rear end still had the saddles on it already. I just had to mount the panhard bar setup.
07-17-2013, 03:43 PM | #11 |
Big favor could you snap a picture of it installed ?
