04-29-2013, 08:19 PM | #1 |
4l60 wiring help!!!
Need some help from all you wiring tranny guys. I have a 5 wire plug in my tranny that is a 4l60. need help to wire up a switch for the lock up
Posted via Mobile Device |
04-29-2013, 09:31 PM | #2 |
Man of Mini-Talents
Re: 4l60 wiring help!!!
You need to wire it up to a transmission controller (TCU).
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
04-29-2013, 10:17 PM | #3 |
its not a 4l60e it has a tv cable
04-29-2013, 11:10 PM | #4 |
So it's a 700R4? If so it should only have 4 wires on the plug...
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
04-29-2013, 11:40 PM | #5 |
no. not at all. it is a 1993 4l60 not e out of a camaro. it has a round 5 wire plug in it. the lock up sollenoid is a 2 wire type.
04-29-2013, 11:54 PM | #6 |
4L60 is the same as a 700R4, just a different name. 1993 was the first year of the 4L60E. Do you have a picture of the connector?
04-30-2013, 12:07 AM | #7 |
Read post #3 on here:
http://www.thirdgen.org/techboard/tr...ap-wiring.html maybe that'll clarify as long as your old connectors has the pin numbers on it.
04-30-2013, 07:24 AM | #8 |
A 700R4 is also known as a 4L60. From 82-92 it had a 4 pin square Weatherpack connector. In 93 it got an additional pin (I forget why) so it went to a 5-pin round connector. The pins are the same. So you need a shell and you will be in business.
http://www.ronfrancis.com/prodinfo.asp?number=TC-71 even better http://www.hipoparts.com/weather-pac...connector-kit/
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 04-30-2013 at 07:50 AM. |
04-30-2013, 09:43 AM | #9 |
i have the connector eith the wires. ill try it and let you guys know what i come up with. thanks for aall the help. thats why i joined this forum. you guys rock. the best place on the internet for people with our trucks hands down.
05-04-2013, 11:38 AM | #10 |
got it figured out. 12v to pin a, and ground the others. i put it on a toggle switch so that i can turn it on and off.
05-04-2013, 12:03 PM | #11 |
Good deal, glad you got it figured out
05-04-2013, 12:11 PM | #12 | |
You'll love this auto-lockup along with your manual override . Sam |
