![]() ![]() ![]() ![]() I just rebuilt my front end on a 1978 Chev 3/4 tonn long box 4 ball joints and upper control arms, plus Now I've gone crazy a took in my neighbours 81 Chev full size van! Will the parts fit on the Van???????? Or should I use the pick up frame with the Van Body? ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
yeller
So what are you going to do with the truck? Why not rebuild the van front end as opposed to swapping out parts?
Is the truck a frame only with no body? It sounds like alot of work to swap bodies as opposed to rebuilding the front suspension on the van. ...Jeff |
The trucks frame is good and the suspension is brand new!
But the body is shot and so is the box! I want a van, but if all the new front end parts won't fit on the van than I don't know what I going to do with the $1000.00 I got into the suspension! The motor is also going into the van! lots of work, but I got time to burn! ![]() I 'm hopeing the parts will bolt right onto the Van! 4 ball joints and upper control arms????????? Cheers ![]() ![]() |
