Old 05-01-2013, 09:19 PM   #1
jsdoyle
jsdoyle's Avatar
Engine temperture
My truck ran at 180 degrees all last summer. Sitting at a stop light or in traffic it would creep up to around 200. Not too bad.
Last fall after the outside temps had dropped I had to put a new radiator hose on so I also put in a new 180 degree thermostat.
The few times I took it out over the winter the truck warmed up fine to around 180. No problem.
Well now that the outside temps are warming up, today was around 80, I've noticed the engine temp when driving is up to 200. Higher when sitting still. I also had a little antifreeze come out the overflow one day after cutting it off and going into a store for a few.
So, I'm wondering what's up with the temp? Is it a bad thermostat? Water pump seems to be working just fine.
I bought a 160 degree thermostat tonight. Does anyone think that might help?
Any other ideas? We had some really hot days last year over 100 for almost the whole month of July. I don't want to see what happens when it gets that hot again this year.
65 Chevy C10 Fleetside
jsdoyle is offline   Reply With Quote
Old 05-01-2013, 09:24 PM   #2
Sharps40
Re: Engine temperture
waterpump/fanbelt/shroud?
Sharps40 is offline   Reply With Quote
Old 05-01-2013, 09:38 PM   #3
jsdoyle
jsdoyle's Avatar
Nothings changed there. Fan belt and shroud are good. Waterpump shows not sign of giving it up.
Old 05-01-2013, 09:49 PM   #4
akaupp
What temp t-stat was in it last year? Different brand?
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 05-01-2013, 10:11 PM   #5
jsdoyle
jsdoyle's Avatar
Not sure about the old t-stat. It came with the truck.
Old 05-01-2013, 10:16 PM   #6
akaupp
If all things other than t-stat and upper hose are the same, I'd bet it was ~160 in there before.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 05-01-2013, 10:21 PM   #7
Rufton
It is possible you got a defective T-stat.
160 T-stat won't help prevent engine from overheating.
160, 180 and 195 t-stats are all wide open when coolant 200F.
It is normal for coolant to escape radiator following hot shut down.
195F t-stat was tested to be best choice for minimizing engine wear
Rufton is offline   Reply With Quote
Old 05-02-2013, 08:33 AM   #8
jsdoyle
jsdoyle's Avatar
Thanks for the info. I'm thinking the same thing on the different t-stats but something is different from the previous set up that's making the truck run hotter.
I don't think putting in a 160 t-stat will make a difference either. Unless the one in there now is simply defective. Easy enough to swap out so I'll throw the new one in there and see where I'm at.
Old 05-01-2013, 11:46 PM   #9
63burban
Chevy addict
I always check new thermostats in a pan of water on the kitchen stove with a cooking thermometer. I had two in a row that were funky. 180 is the best, I had one that fully opened at 190 and one never really fully opened, I also had one that you needed to rap on the thermostat housing to open or the truck would boil over. Dug a used one out of a drawer in the shop, it started to open at 180 and was fully open at 185, that's the one I installed and it's been there several years.
We cruise the fair grounds at Back to the 50s with it and it doesn't get over 190, it's got a 283 and th350 in it, we pop it in neutral when we stop and it comes right down to 180. It has a cheapie aluminum radiator and a home made fan shroud with a 5 blade clutch fan.
63burban is offline   Reply With Quote
