Old 05-05-2013, 01:26 PM   #1
fnsteffen
Question What's it Worth?? ('57 3200 Long Bed)
I tried to post this on the general WIW board, but I'm not allowed to for some reason. Still new here obviously, and I'm not sure how everything works. Hope it doesn't tick anyone off that I'm posting here..
Anyway, I'm currently negotiating a deal for this truck, and I was hoping to get some advice from more experienced folks. Would y'all mind taking a look and letting me know what you think it's worth?
It's a 1957 Chevy 3200 Long Bed. It still has the original Stovebolt Straight-6 that ran when it was parked about 5 years ago. I doubt it would turn over right now, but I'm planning on rebuilding it anyway. The interior is long gone. The wood bed is still in tact, but not in great shape. The patina is pretty awesome, so I'm thinking about keeping that and going with the old "shop truck" look with a restored interior and engine.
What do y'all think? Need any more information to put a value on it?
Thanks in advance for your help!!
fnsteffen is offline   Reply With Quote
Old 05-05-2013, 01:46 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: What's it Worth?? ('57 3200 Long Bed)
A moderator will be shutting you down soon. You're not allowed to post "What's It Worth?" "For Sale" and "Wanted To Buy" threads unless you're a paying member. And I'm not sure about responding to them either which is why I'll post no opinion.
Sorry to tell you but someone else will very soon anyway.
Unrelated to it's value, some guys are patina fans, some are not. Count me with the "not" crowd. It's not that I don't like how it looks if the patina is mild - faded paint, multi color. But when it's heavy rust like this truck I can't help but know the rust is literally eating your treasured truck to pieces. Personally, I could not stand to allow that to continue on mine.
Dan in Pasadena is offline   Reply With Quote
Old 05-05-2013, 01:56 PM   #3
fnsteffen
Thanks very much for the explanation. I'll check out the paid membership deal.
Regarding the patina, I've only recently started looking into that style, but I was under the impression that it was posisble to "neutralize" the rust and then seal it with a clear coat. Is that not the case? I definitely don't want to have it continue to rust apart while I drive it.
Thanks again. I appreciate your advice.
EDIT: I just got a year membership, so hopefully they don't shut me down now.
Old 05-06-2013, 06:48 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
I've seen some good result using CLR and scotch pads.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-06-2013, 07:55 PM   #5
Dan in Pasadena
fnsteffen - Just so you know the CLR removes the majority of the rust and the rusty look but does expose the paint patina. But to keep the rust from coming back you'll have to rattle can on some flat or satin clear.
Old 05-06-2013, 08:58 PM   #6
fnsteffen
Thanks so much for your replies! I really appreciate the help.
I hadn't heard of this before, but I saw some pretty neat results after googling. Most notably this guy (BEFORE and AFTER). Looks like it helps refresh the paint and still leave a nice patina. The only thing I'd be worried about is if there's no paint left under all that rust and all I do is expose a bunch of bare metal. But that doesn't seem likely.
Per broey's comments, that's an awesome break-down! I guessed that the small window and long bed would hurt the re-sale, but I actually prefer both of those options to the more popular alternatives. I think they make for a more balanced and better-looking truck for my taste. I'll have to check out the cab corners again, but I think they were in good shape. I know the motor is still free, but it's going to take me a little work to get it started. As I mentioned, I'll probably rebuild it anyway just to be sure. But your comments help out a lot, as do your recommendations for what to do!
Yeah, I can see that possibly being really great. Like I mentioned above, I just hope there's not a bunch of bare metal under there. I have a few friends with paint set-ups, so I figured I could shoot a few coats of flat or satin clear on it after treating the rust. But would I have to do anything after the CLR to prep it for the clear? Seems like it would be super acidic after the CLR.
Originally Posted by dubie
The CLR and scotch brite pad works great to remove the rust and expose the raw material underneath but as Dan mentioned, you'll have to lock it it with some adhesion promoter and some satin clear
Would any adhesion promoter work on that kind of surface, or does it need to be a certain type? I've only used primer in the past, and obviously that won't work.
Originally Posted by mr48chev
I'm not a fan of rust for the sale of rust and have never understood the "rusted out shop truck" thing. Most guys I have known who had a real shop truck and a business has wanted a damned nice shop truck to promote his business and a cruddy looking truck would be a detriment to the business.
I definitely see where you're coming from, and I don't blame you at all. I do not have a shop or any business that I will be promoting and only mentioned the "shop truck" thing to give an example of what I'm thinking. For me, keeping the patina is more about showing the character and uniqueness of the truck than it is just for the sake of rust. There are plenty of turquoise '57 chevys out there, but none with this exact patina. And it just seems like a shame to cover up something one of a kind just to make it more like all the other ones out there. But, again, that's just my personal preference.
Thanks again everyone!
Old 05-06-2013, 07:44 PM   #7
broey
Square
broey's Avatar
ill chime in, while some may not like patina, it's actually a good thing to see when buying a truck. let me explain why... when looking at any car or truck one thing everyone says is what does the body look like? has it been in a wreck? or is the paint new? something along those lines, but with a patina'd truck, you are looking at the original paint. so no hidden bondo jobs or crappy patch panels anywhere that were hidden until you media blast the truck after you get it home and have paid. so, the real car buyers out there will actually look for original paint. its a way better indicator of the trucks life than anything else. I hope that makes sense. plus, patina is just sun burn with a top coat of rust, absolutely nothing to be affraid of.
now as far as the truck in general, small window, long bed, non optioned, inline 235 are all important to think about when buying a truck(unless you wanted a long bed that cant go on the freeway) those are all things that are less desirable as far as value/resale goes.
the good things going for it are, single headlight, seems to have everything with it still, and original paint
now as far as rust. look at the cab corners, and look inside the hinge pockets on the door hinges, those are the two places that are most common to rust. The hinge pockets are a pain in the butt to repair, and the cab corners will ruin the patina, because you will have to cut and weld. so check those out.
all said and done, if the 235 is at least free, its going to run those things are indestructible.
if the cab corners are rusted, the interior is shot, and the motor wont start. $1000 tops
no rust, motor atleast rotates, and the interior is in it and atleast usable $1500-$2000
Squarebody Syndicate
broey is offline   Reply With Quote
Old 05-06-2013, 07:50 PM   #8
broey
Square
broey's Avatar
on a side note, if it were my truck, I would:
fix the glass
shorten the frame
cut the bed sides at the cab to shorten the box
replace the brakes, fuel system and get the motor running
drop axle up front and flip kit in the back
wide whites on the original wheels
remove the rear bumper for a swap meet find bumper in white
and re-wrap the seat
those are all budget friendly and will make one bada$$ truck.
Old 05-06-2013, 10:32 PM   #9
red yj
fix the glass
shorten the frame
X2 that truck is perfect to me.. I like it.
red yj is offline   Reply With Quote
Old 05-06-2013, 08:12 PM   #10
dubie
dubie's Avatar
that truck, sitting in it's current condition, not running would fetch $1500 all day long. With a bit of elbow grease in getting it running, driving stopping and some rust touch up, you'll easily double that amount or more. The CLR and scotch brite pad works great to remove the rust and expose the raw material underneath but as Dan mentioned, you'll have to lock it it with some adhesion promoter and some satin clear
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-06-2013, 08:35 PM   #11
mr48chev
mr48chev's Avatar
I sold a GMC Big window with about the same amount of rust and a nice chrome grill and bumper for 300 a couple of years ago and had a hard time getting that. I'm not a fan of rust for the sale of rust and have never understood the "rusted out shop truck" thing. Most guys I have known who had a real shop truck and a business has wanted a damned nice shop truck to promote his business and a cruddy looking truck would be a detriment to the business.
Truck prices around the country have several factors involved and where you and the truck are located is the primary one. Here where I live you can find a truck like that and drive it home for under 1000 with a clear title. Back in the rust belt guys might think it's a 2000 dollar truck if it has a clear title running or not. In other areas of the country it's worth anywhere from what the scrap yard offers up to maybe 2500.
My ongoing truck projects:
Old 05-06-2013, 09:02 PM   #12
broey
Square
broey's Avatar
Edit: Let us know if you get it.
Old 05-06-2013, 09:09 PM   #13
fnsteffen
Haha, I was just about to reply and say that I replied to you too! You just wrote so much, I didn't think I should quote everything.
Thanks again for your advice. I'll be sure to let you know if/when I get it!
Old 05-06-2013, 09:14 PM   #14
broey
Square
broey's Avatar
Had to chime in one more time. You don't need to do anything to the paint. it took what, 56 years to get the paint to that point. you don't live in Seattle where it rains and snows every day. check out Jackalope. this truck has just as much patina as yours, and its been fine, it was in Arizona for a few years and never got any worse. spend your money on other parts of the truck, because the paint is fine.
Old 05-06-2013, 09:14 PM   #15
broey
Square
broey's Avatar
jackalope
Old 05-06-2013, 09:26 PM   #16
rgunlock
rgunlock's Avatar
Having spent a few years keeping an eye on Houston CL for these trucks, make sure it's got a clear title for the kind of prices being mentioned.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 05-06-2013, 10:05 PM   #17
broey
Square
broey's Avatar
yes, what he says. very important.
Old 05-06-2013, 09:40 PM   #18
G&R's57GMC
G&R's57GMC's Avatar
So you start with a nice patina and get an occasional thumbs up, add a theme and get a bunch of thumbs up and "What will you take for it" questions.
The Texaco sign was added last month, my guy even continued the 'scratches' onto the sign.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 05-06-2013, 10:24 PM   #19
SCHRUMGMC
SCHRUMGMC's Avatar
Like the truck, very nice man,I hope you get it
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 05-06-2013, 10:32 PM   #20
dwcsr
Hollister Road Co.
dwcsr's Avatar
Get the Mobilgas gas pump in the background its worth about 2500 by it self.
Old 05-06-2013, 10:30 PM   #21
fnsteffen
Thanks for the advice. The Jackalope looks pretty sweet! I agree that I shouldn't do too much to the paint, but I feel I should at least do a little to protect it. Houston isn't Seattle, but it is a very humid climate, and rust isn't negligible. This truck has been in central Texas where it's drier, and I'm not sure how it'll react to the new humidity. Also, the fenders above the headlights have already rusted through, and I'd REALLY rather that not get any worse. I'm going to keep an eye on it for sure.
Yeah, that sign is awesome! I've been thinking about designing an oldschool logo for the door as well, but I hadn't the slightest clue how to age it appropriately. Does your guy do that often?
The title is clean and clear, so we're good to go there.
You guys are great with all the advice. Much obliged!
EDIT: had to censor myself. oops.
Old 05-06-2013, 11:03 PM   #22
fnsteffen
Holy crap, really?? In that condition or fixed up? This is an estate sale of sorts, so they're just getting rid of a bunch of old stuff. I could probably pick it up, but I'd have no idea how to re-sell it.
Old 05-07-2013, 06:50 PM   #23
G&R's57GMC
G&R's57GMC's Avatar
This is what my guy did to a pump in that condition for $2200 in 2002.
I paid $ 500 for this pair of pumps in 2004.
So a pump in that condition would go for $ 250 - $ 500, IMHO.
Glen & Jane's Rides
Old 05-14-2013, 02:47 PM   #24
fnsteffen
So I went back to check out the truck again, and I got a lot of good pics. Pretty sure I'm going to buy it for $1,200, and he's holding it for me. All the rust looks like it's just on the surface, and the only place I could find where it rusted through was over the driver's side headlight. The engine was rebuilt and then driven for about 50k miles before being parked, and it hasn't been started since. I'm hopeful that I can get it running without too much trouble.
What do y'all think? Anything I should be worried about?
Old 05-16-2013, 01:33 PM   #25
Dan in Pasadena
Originally Posted by fnsteffen View Post
THIS photo?
As an aside I found out the jack out of an early 2000's Ford F350 fits right in the same place like it was made for it. I had a company-provided f-350 and it walked over and installed itself in there one day
Back to Steffen,
I had to go re-review your photos (man, you posted a LOT of them!) to find this photo and I think the first thing I'd do is blow it out w/an air hose or leaf blower.
Then a couple gallons of CLR and a few Scotch-Brite pads will make a HUGE HUGE difference. I think it'll be shocking how well it will clean up. Can't wait to see it!
