Low budget rear suspension builds..
Has anyone here built/put together a cheap rear suspension that looks and functions well? I have a 54 GMC I picked up dirty cheap that already had a Heidts Superride 2 front suspension now I just need a decent rear setup but dont want to pay 800-1200 for heidts/tci/etc..I love the idea of using current automotive factory pieces from junkyards but havent seen any other than Jag rears which seem to be more work than its worth. I did notice recentley I think on a newer durango it appeared to have a watts rear link setup..
Re: Low budget rear suspension builds..
A couple of the guys are running Mopar Mini van rear leaf springs but I don't know if they are the long or short ones. Real simple and dirt cheap and they unbolt from the van with all of the brackets real easy. I've got both a Grand Caravan and a Mini Ram van to look under for measurements to see how they work for my truck.
Years ago I used to check out every different suspension setup I saw on a rig I worked on to figure out if it could be used on a hot rod or truck. Since I don't work in a shop anymore I've lost track of what is out there.
Look into Ford 8.8 rears. Running one in my '49. They are available in the Ford Explorers, see the article below. I believe someone in here is running the complete rear from the Explorer (leafs, rear end, and sway bar).
I am running the rear and am putting the rear sway bar in. http://www.therangerstation.com/tech...plorer8_8.html
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
![]() Join Date: Jun 2011
I have a low budget 4 link in my 59. The 4 link kit was around $200 from summit. The coil over shocks were around 250. The 51" wide dana 44 out of a 75 Jeep CJ5 was 100 bucks. I made it disc brakes but you really do not need to. I'm sure there is a couple things I missed but not a lot of money for a 4 link and narrow rear.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
#5 | |
+1 on the exploder 8.8's for an axle. easy to find, tons of parts, and tough. I put one under my 59 and held it into place with a 4/watts link I put together. Check out welder series kits. The guys on the TV show Trucks used them for some suspension kits. http://www.welderseries.com/blog/online-store/
Rookie, you just gave me what I needed to get back on my project. I'm sure you all think I've given up just had other priorities getting my race car together.
2006 Chevy Silverado 3500(Duaramax/Allison) - DD 1997 Honda Civic - Work Beater 1981 Chevy Malibu - Race Car 1959 Chevy Truck - Project http://67-72chevytrucks.com/vboard/s...d.php?t=481442 2006 Honda Accord - Wife's ride |
I have $300 into mine mostly coil overs. I used a 76 Monty Carlo rear end control arms/ sway bar and made a cross member and mounts.
It is spread through the first and second pages of my GMC build thread. Last edited by mknittle; 05-05-2013 at 09:52 PM. |
Ford/lincoln IRS set ups look extemely easy to install as a complete system ride well, carry a load and lay out nice.
Posted via Mobile Device |
I have an 94 mercury cougar 8.8 IRS in my full size 94 bronco with 06 crown vic front IFS and like the way it works. I found a complete TCI parallel rear kit with coilovers and panhard for 850 to my door so I think I am just gonna go that route as i already have the explorer 8.8 with discs and 3.73's. Also found a 1949 chevy deluxe cab complete truck this week that I am dragging home.
I'm in the same boat. Looking at a complete set up for $875, but they're telling me that the shock mount won't fit a 3/4 ton Chevy. Anybody got a lead on one or measurements that I can use to make one?
Ive got about 600 in mine. I think it was money well spent.
TCI rear leaf kit 99 Explorer 8.8 Discs, Ebrakes and posi. ![]()
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
Mine is really low buck.
$75.00 for '97 blazer rear end (3.43) $25.00 S-10 leaf springs $50.00 for KYB rear shocks $40.00 for 1" lowering blocks $25.00 for misc metal for fab ![]() |
