Old 05-05-2013, 09:56 PM   #1
Daddy Brim
Daddy Brim's Avatar
Factory Assembly Manual, Navigation
I got a Factory Assembly Instruction Manual, and I can see there is a lot of good info in there. How do you find the info that you are looking for, no index no table of content or page numbers ?
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 05-05-2013, 10:04 PM   #2
Bomp
Bomp's Avatar
Re: Factory Assembly Manual, Navigation
I've thumbed through page by page. I have pieces of paper with the name (windshield)etc. on top.
Bomp is offline   Reply With Quote
Old 05-05-2013, 10:13 PM   #3
Route-66
Route-66's Avatar
It's a PDF file so you're probably using Adober Reader to read it.
On the left side of the page click the "paperclip" and then the "binoculars" and then you can do a text search for whatever part you're looking for.
Hope this helped.
Route-66 is offline   Reply With Quote
Old 05-05-2013, 10:48 PM   #4
Daddy Brim
Daddy Brim's Avatar
This is what I have been doing. I also have a Chassis Service Manual and a Haynes Repair Manual, are there any other good books to get ?
Old 05-05-2013, 11:31 PM   #5
Bomp
Bomp's Avatar
These are the two manuals I have.
I also have other books (you can see them spread out on the floor around the 9 minute mark) in this video. Seeing how other forum members dealt with situations helps out too.
Old 05-05-2013, 11:46 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
It is my understanding that the Factory Assembly Manual was not designed to be a reference manual. It was used on the assembly line for assembling the vehicles, and sections in the book are in sequence with the way the vehicles were assembled on the different sections of the lines.
I purchased the CD version of the manual from here.
http://www.gregsonline.com/eshop/Assembly/67TFAC.htm
It has a search feature that works very well.
They also have some neat '67-'72 Chevy "T" shirts if you click on the "licensed apparel" at the bottom of that page.
LockDoc
Leon
Old 05-06-2013, 01:07 AM   #7
FirstOwner69
FirstOwner69's Avatar
You can try this link. I found it here on the forum about a year ago. It will require that you number all pages... 1064 if I recall correctly. I'm also not sure the document is complete.
https://docs.google.com/spreadsheet/...sOXcwVWc#gid=0
FirstOwner69 is offline   Reply With Quote
Old 05-07-2013, 08:19 AM   #8
Daddy Brim
Daddy Brim's Avatar
Thanks, this is just what I was looking for.
Old 05-07-2013, 09:24 AM   #9
LockDoc
LockDoc's Avatar
On the extreme right side of the spreadsheet it lists the board members that contributed time & expertise to this project. A big thanks to them...
LockDoc
Leon
Old 12-11-2013, 02:40 PM   #10
Jahloha
Jahloha's Avatar
A little late to the party, but here is a link to an index that was created by some of our members a few years back. Check out Post #9 for the link to the Google Doc that contains the index.
http://67-72chevytrucks.com/vboard/s...d.php?t=351185
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 05-07-2013, 08:17 AM   #11
Daddy Brim
Daddy Brim's Avatar
LockDoc
I understand that this book was used on the assembly line. I was wondering if anybody took the time to make a referance chart or somthing like that. I'm very old school and a Binderyman by trade, so like paper and books. I try to get all of the books I can for the vehicles I own. Maby I will need to get me that CD version.
Old 12-11-2013, 03:56 PM   #12
Keith Seymore
Keith Seymore's Avatar
It is compiled in UPC order (no relation to assembly order).
So UPC 0 = Labels/literature
UPC 1 = body structure
UPC 2 = Frames
UPC 3 = Front axle
UPC 4 = Rear axle
UPC 5 = Brakes
UPC 6 = engine
UPC 7 = transmission
UPC 8 = exhaust
UPC 10 = tire/wheel
UPC 11 = front end sheet metal, radiator support
UPC 14 = bumpers
It is cumbersome, at best, to use, even for those guys that have grown up with it. The only way to navigate quickly was to create your own cheat sheet (in the pre-internet/per-computer days) or use a search feature as you guys have done.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-06-2013, 09:24 AM   #13
Lee H
Lee H's Avatar
I also have the CD version, it's easy to use, searchable and I can print out a page or two if needed. I have it on my iPad so its handy were ever i need it. Before I got the CD version I made an index in excel, it only takes about an hour and makes things a lot easier to find. I have not used the tome since I got the digital version.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
