Old 05-06-2013, 07:45 AM   #1
68Stepbed
68Stepbed's Avatar
Riddle me this................
OK, I've had a popping noise in my front end for a while now. I never noticed it before the LS swap. I only mostly heard it when barely moving the steering back and forth.
I took it to a shop this past week. Nothing in the steering/suspension is showing any signs of wear or unnecessary movement, but the noise was still apparently obvious. We noticed the sound would resonate through the frame, and could be felt when holding the frame. Then we noticed it was felt even more through the crossmember brace. Not the main engine crossmember, but the one in front of the engine. The mechanic used a stethoscope and discovered the noise was most audible there as well. We did notice that the top left hand factory rivet was slightly loose. The passenger side was still tight. The lowers have been replaced with bolts when I added the sway bar years ago. The bolts were also still tight.
Has anyone ever had this issue before? For the time being, I plan to grind out the factory rivets and replace with grade 8 bolts, but shortly in the future, I'll probably replace with a Porterbuilt tubular core support brace, or make one very similar.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-06-2013, 05:23 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Riddle me this................
Check the frame by the steering box. Common area for them to crack there
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-07-2013, 08:08 AM   #3
68Stepbed
68Stepbed's Avatar
That's just it. The frame isn't cracked. The noise is an apparent stress reaction in the forward crossmember. I was just wondering if anyone else has had this happen on their truck(s).
Matt
Old 05-08-2013, 12:45 AM   #4
king-918
king-918's Avatar
Put it on a alignment rack with someone inside so you xan pinpoint the noise
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-08-2013, 03:12 AM   #5
andrewmp6
Check the bolts on the steering box loose can make sounds,A loose or cracked sway bar can do it too.
