Tail light harness connector
Im looking for just the connector for the taillights. Im taking the bed off tonight, and it may be off for a couple weeks. I would like to still drive the truck while its off, but im not really fond of the idea of just splicing some wires into my existing harness. If I could find just the 4 way connector and just wire it up to that, id be happier. Is there an outlet or does anybody know an A/M place to get one? Id appreciate the help fellas
Thanks -Andrew The female side of this |
Re: Tail light harness connector
I think Reese makes a "T" plug-in that goes between the frame harness & tail lamp harness for trailer hookup. Just cut off the flat four connector & make yourself a lightbar.
yep easily found any auto parts store boat stores trailer and rv places i've even seen in walmart
#4 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Not to sound like an idiot, but I guess I haven't had enough experience with em, cause Im lost. Does it look like our connector, or will I have to get some connectors and just make it?
If they do, I cant find one.
Wouldn't four standard male slide-on connectors work for a short term project?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Exactly what I was thinking.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
but if he ever gets around to puttin the bed back on it is just a plug in deal and he is already setup with a trailer light connection too
