Old 05-08-2013, 08:42 AM   #1
68Stepbed
68Stepbed's Avatar
ECE rear KYB shocks part number?
OK, ECE sells the GR-2 rear shocks for lowered trucks. I need a set, but don't want to wait 4 days to get them from ECE. Does anyone know the actual KYB part number for these particular shocks?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-08-2013, 04:35 PM   #2
cericd
cericd's Avatar
Re: ECE rear KYB shocks part number?
I found this info in Nate's "Blank Slate" build.
Originally Posted by 72BlckButy View Post
Now to put an end to the never ending saga of determining which KYB shocks to use on a lowered vehicle. According to the boxes shipped by ECE, and after confirming the number with the shock themselves, here's the numbers you need to correspond with your local KYB dealer:
02-7002 Front KYB GR-2 Drop Shock (344068)
02-7510 Rear KYB GR-2 Drop Shock (344055)
The numbers 344055 and 344068 are stamped into the shock, and is also part of the UPC printed from KYB.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
