Old 05-08-2013, 11:22 PM   #1
Zable49
Zable49's Avatar
Yup me again with another question
Ok, so I was cleaning out the "collect all" areas on my firewall and I realized that I couldn't get to all the areas. Do you think it would be ok if I drilled a couple of 2inch holes on a few different areas (red arrows) so I could clean out the whole area and keep it cleaner...
1970 C20 Camper Special
SBC350 / TH350
'84 C20 Front Disc Brakes/Control Arms
Zable49 is offline   Reply With Quote
Old 05-08-2013, 11:31 PM   #2
Roninwolf
Roninwolf's Avatar
Re: Yup me again with another question
All you have to do is take out the kick panel vent doors to get those area's.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 05-08-2013, 11:35 PM   #3
Zable49
Zable49's Avatar
Oh really? I didn't even think about that but it makes sense.
Thanks.
SBC350 / TH350
Old 05-09-2013, 12:18 PM   #4
MidLifer
MidLifer's Avatar
...or just open the vents while driving around and let the crap blow out all over your legs and floor! LOL
MidLifer is offline   Reply With Quote
Old 05-09-2013, 12:29 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
but it does work though
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-09-2013, 12:44 PM   #6
ItsRandy
ItsRandy's Avatar
I used a Shop-Vac with a smaller hose adapted (duct taped) to the end and jammed it in from both directions (with the vent removed). It took a little time but not much. Oh...don't use your wife's vacuum hose, she won't let you forget it. Don't ask me how I know.
ItsRandy is offline   Reply With Quote
Old 05-10-2013, 01:38 AM   #7
Zable49
Zable49's Avatar
Gosh, your no fun. I really want to use our Kirby in the garage. Taking all my fun away.
Appreciate it guys, I will remove the vent and see what I can get.
SBC350 / TH350
Old 05-10-2013, 08:34 AM   #8
camrycurt
camrycurt's Avatar
Like the other guys, I removed the vents and used my hands, shop vac, screwdrivers, etc. to get all the big pieces out and then flushed that area with some water to clean up the rest. Once you unclog everything there is a drain at the bottom of the outer edge of the vent to flush the grime away.
After that I ran the garden hose into the cowl from above (after cleaning that out too) and flushed the whole works really good with lots of water to make sure everything was clean and any water could drain.
All the junk that fills those areas up comes in through the cowl below the windshield so if you haven't already put a screen in place under there to keep the debris out you might want to consider it. It helps to keep the big pieces out.
Good luck!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 05-10-2013, 03:30 AM   #9
SS Tim
SS Tim's Avatar
Actually I could see a case for cutting a hole in the outer panel opposite and below the vent to allow cleaning and rust prevention measures you really can't do around the "bell" of the vent hole. Then a semi-permanent coverplate sealed and riveted in place to keep it airtight.
SS Tim is offline   Reply With Quote
