![]() Join Date: Dec 2012
Sway bar bushing
Hey guys
I was installing the sway bar and noticed that the angle of the sway bar at the lower arm on the passenger side was at an angle not up or down but from drivers side to passenger side and when I lower the truck back on the ground the bushing started to pop out where the split is. Is the split of the bushing supposed to be on one side or the other? I have seen in other pictures both ways. The bar was straight and lined up between the bolt holes on the a arm. What should I do? Re drill the inside bolt hole towards the back of the truck so the bushing sits at the same angle as the sway bar? Posted via Mobile Device
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Re: Sway bar bushing
Can you take a pic of what you are talking about?
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
I forgot to before I left last night. (Late night). I will try tonight sorry.
Ok that's cool. I just put on my sway bar too. I doesn't matter which way the split on the bushings go on. There should be 2 bends on each end of the bar where it clamps to the a arm
Mine is the original that came with the truck. I just painted and replaces bushing After lowering it.
Watch out for your cornhole !
![]() Join Date: Jun 2003
You've likely got the bar on upside down. It's easy to do and will cause the bushings to open up like that since the angle is wrong.
Posted via Mobile Device |
I looked at the forum and the sway arm has a curve to keep it away from the steering pitman arm and idler arm. Right. ?
I've put a bunch of them on over the years, and just a few months ago, I put mine on upside down until I figured out my mistake. It's easy to do.
Here it is after I turned it over the right way. It was prying the bushings open like you describe before I flipped it over right. ![]() Posted via Mobile Device |
#9 | |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
That's how mine looks. Same as the picture.
Here is a picture of the bushing that popped out
Looks like you may not of had it sitting right when you bolted it down
possible it was a long night!!!! I will try and reseat it. possibly to much lube!
#15 |
I took the wheels off and reset the bushing and maid sure the bushing was seated as I tightened it. It seems to be ok we will see once I get the alignment and drive her.
#16 |
Ok cool let us know
#17 |
That paint does look good.
#18 |
What type and color of paint is that?
#19 |
It's silver vein powdercoat. I order it from NIC Prismatic. Their powder has the most pronounced vein effect of all of them out there that I've ever seen.
#20 |
Scrapper 1
look up WWW.4Wheelwest.com they make a Zerk fitting like your ball joints and A Arm bushings where you can take a grease gun and Lube your sway bar bushings i think i have a picture of my 1965 3/4ton with them
