Old 05-09-2013, 04:35 PM   #1
jenk
1984 K10 AC Troubleshooting
I bought the truck in winter so I didn't think to test AC. It does not blow cold so I jumped the low pressure switch and the compressor came on. I noticed that it already had the R-134 adapter on so I bought a 20oz can of ACPro to put in it. About half a can in and compressor kicked on the right back off and will continue to do that until you turn AC off. Does this mean I need more 134 in it? The pressure would rise from around 25-30 up to 50 or 60 and compressor would kick on and bring it down then stop. Any advice would be very much appreciated.
1984 K10
1990 K5 Blazer
1976 C10
jenk is offline   Reply With Quote
Old 05-10-2013, 01:02 PM   #2
pontgta
pontgta's Avatar
Re: 1984 K10 AC Troubleshooting
yes you need more 134/ freon, but you most likely have a leak. Charge and then leak test with either a leak detector, or use a uv light and dye.
pontgta is offline   Reply With Quote
