Roto Reuter thats the name...
![]() Join Date: Feb 2010
My new hood hinge springs bent my genuine GM hinges! Crap!
I'm ticked... I bought nice genuine GM hood hinges from Wes at Classic Heartbeat. The aftermarket hinge springs that I bought were so strong that they bent the hinges inward and ruined them. The genuine GM hinges weren't cheap either. Anyone else have this problem?
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: My new hood hinge springs bent my genuine GM hinges! Crap!
I used repo springs from Brothers with original GM hinges without issue. Where did the springs come from? Posted via Mobile Device
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Hinge springs came from GMC Pauls.
Yikes!
Anyone else have this problem with aftermarket hinge springs?
Cluster King
![]() Join Date: Nov 2012
That really sticks. How hard were the springs to install? It sounds like the new springs may have been a little short. You need to measure a factory one against your spring from GMC Pauls and make sure they are the same length. The factory hood hinge spring have very little tension on them when the hood is open. If the springs are too short, I can see how it would bend the hinges.
If the GMC Pauls springs are incorrect, I would be making some calls. |
#7 | |
The springs need to extend about 1" from the relaxed position to be installed on the hinges. In order to install them, I placed a spring on my floor jack to extend it. I then put wooden shims in between several coils. This extended the springs enough to get them on the hinges. I used wood so I wouldn't scratch the new springs, but the wood was tough to get back out. I then pressed on the hinge to extend the spring in order to remove each piece of wood.
Just for reference, I installed my NOS springs on my NOS hinges (real NOS, not the new stuff with bar codes) with a large screw driver, just pried them over. It did not take much pressure, certainly not a hydraulic jack.
Cluster King
To add to that,
I bolted my hinges on, without the hood on, hooked the rear side of the spring and used a fan belt on the front side and gave it a good pull and they both set right in place. The belt may get on the wrong side of the spring in which case just cut it (junk belts work best for this). I used a lot of blankets around the back side and below just in case the spring fell down. |
LeeH they should not be real hard to install.
Moderator
![]() Join Date: May 2007
I used OEM hinges and springs from a low mileage truck that were in near perfect condition. The springs were not difficult to install, as stated above. I have never heard of hinges (NOS, used, or repop) ever being bent by a spring. They obviously have too much tension if they measure the same. Can you compare the tension in them vs. your old ones?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Mar 2012
I have also installed new springs. They should be fairly easy to pry on using a big screwdriver or small pry bar as stated above. If you needed to use a hydraulic jack to install them, them I'd be willing to guess you have the wrong springs.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
I did a search on this forum and found out that other people have used the floor jack method to install hood springs. Some used wrenches in between the coils as spacers to extend the springs. I also know that the new aftermarket springs are a lot stiffer then my old original springs. I would have used my original springs, but they were all pitted and weren't the best with brand new hinges. Like I said, I replaced the hinges with new genuine GM hinges, so I thought I would replace the springs too. Big mistake. Found out that GMC Pauls springs are not the best.
