"New" bed not lining up?
I have a square body pickup bed trailer that had a horribly rusted out floor and bed side. I have no idea what year it was but definitely a square body. I found out only 3 bolts were holding it in. I took it off and I bought another square body bed for 120 bucks. I put it on and only 4 of the bolts lined up. 2 on the front, two on the rear. Why won't the others?
My names Tye. No Chevy right now ![]() |
Re: "New" bed not lining up?
Bolt holes were in different places for different years, Just get a long bit and drill new holes through the frame. I doubt it is going anywhere with 4 bolts in anyways.
![]() 1985 C10 2004 Avalanche |
If I re-drill the holes in the frame to line up with the holes, it will not have any metal on it left. It's only off by about a quarter of an inch. Can I drill the bed floor and crossmember?
Ya you can drill the box and cross-member, just watch when you tighten them down as the original box floor holes have a crush sleeve in them.
? Are these meant to be "crushed"when bolting the bed down?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
these 'sleeves' are meant as an anti-crush mechanism. so that when you tighten the bed bolts down they do not warp the sheet metal of the bed floor.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
Ya sorry, I should have said anti-crush.
cool, thanks
It's sort of like a really stiff spring. It saves the factory time. They're normally used in rear differentials. The spring effect of the buckling of the sleeve provides a pre-load greater than any force that can release it. It's basically a strong spring.
