Old 05-13-2013, 12:23 AM   #1
king-918
king-918's Avatar
help with x-member
Putting my cross member back together but I haven't a clue what the the bolts should look like as far as size and placement. Any help and pictures are welcomed
ALSO the mount engine brackets on the cross member has two sets of mounting points which ones do I use
86 SWB 350/350
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-13-2013, 07:04 AM   #2
wraprail
wraprail's Avatar
Re: help with x-member
The clam shells use 3/8 x 1" bolts (3 each mount) and the crossmember should also be same bolts. (8 total on crossmember and top of frame)
clam shell mounts are garbage
wraprail is offline   Reply With Quote
Old 05-13-2013, 11:04 AM   #3
SCOTI
SCOTI's Avatar
3/8" x 1.25" would prob be better on the x-member to frame rails to allow washers & full thread engagement.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-13-2013, 11:24 PM   #4
74 stepside
74 stepside's Avatar
The bolts on the frame rail to crossmember are 9/16. Motor mounts use 3/8.
74 stepside is offline   Reply With Quote
