![]() Join Date: Sep 2012
Spid question
Ya, Ya, Ya,,,,another SPID question. It doesn't really make a difference to me but I am curious about something. Would a radio be listed on every SPID in which the truck had a radio? I mean....my SPID does not list a radio. Does that mean the truck did not come with one originally? Or is it something that may or may not have been listed?
Active Member
![]() Join Date: Nov 2012
Re: Spid question
I know mine has the radio listed. I know a lot of trucks those years didn't have radios. Good question tho... U got me curious now
67 C20 283/4 Speed |
Re: Spid question
What made me curious is the fact that there is no hole punched for an antenna in the cowl. I have my antenna frame mounted under the cab.
Active Member
Re: Spid question
Well then if that's the original cowl your truck definitely didn't come with a radio.
Re: Spid question
That's what I was thinking. It doesn't make a difference one way or another, I'm not doing any kind of restorations. I was just curious.
Re: Spid question
From everything I've learned about SPID sheets, if it came with a radio then it would be listed on the SPID, and it will also designate either AM/FM or just AM.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: Spid question
It's hard to read but there isn't much listed. 350 V8, TH transmission, HD springs, ammeter, anti-glare mirror, green vinyl, full foam bench.....Nothing about radio. |
Re: Spid question
If the radio is not listed on the SPID it was not factory installed. Radios were not part of any option and were stand alone. So if you wanted a radio it had to be ordered or a dealer accessory radio install kit could be used.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Moderator
![]() Join Date: May 2007
Re: Spid question
I would think your truck would have had a radio delete plate as well
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#10 | |
Re: Spid question
When I got the truck it had a Spark-O-Matic radio in it with horrible speakers and no antenna. So I frame mounted an antenna and put a cheap Kenwood receiver and speakers. It sounds ok. Usually I just listen to the rumble of my exhaust though. LOL |
Re: Spid question
Mine has the radio delete and no radio listed on the spid. But somebody punched a hole in the cowl for the antenna which is currently not installed.
Posted via Mobile Device |
