05-14-2013, 09:04 AM | #1 |
Where to find air cleaner support bracket for a Rochester model BV carb?
Hey guys,
I'd like to put the stock air cleaner back on my truck, but both model BV carbs that I have are missing the air cleaner support bracket that I circled in red in the attached picture. I have no idea why two different POs would remove that piece but evidently neither one liked it much. Does anyone know a supplier that sells these? I found this one at QuadrajetParts.com http://quadrajetparts.com/rochester-...01-p-1020.html and two similar choices through Walker Products but all of the ones I found appear to screw on to the top of the carb whereas the stock bracket in the picture (the same as the two carbs I have) seems to twist into a slot in the side of the carb and is held in place by two pins. I think to fit correctly I need to find the stock piece. I know it's a long shot, but thanks for any thoughts on where to find one of these. I'm thinking I should post over in the 60-66 forums because there's probably more Rochester B guys over there. I'm guessing this will probably be something I'll need to fab up myself or get used off the parts boards. Thanks for the help!
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
05-14-2013, 12:55 PM | #2 |
Msgt USAF Ret
Re: Where to find air cleaner support bracket for a Rochester model BV carb?
Here's an idea I had. 2.5 inch should be wide enough.
Trim as needed and drill hole in center for the stud. use the lower half of course.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-14-2013, 08:25 PM | #3 |
I didn't see any listed at this time, but this guy usually has the off-the-wall parts:
http://www.carburetor-parts.com/ Might be worth a phone call to see. You might have to try to find a donor carb, though. You may also be able to modify one from a different Rochester, like a more common Mono jet or something. There's really not much to them.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
05-14-2013, 08:36 PM | #4 |
Active Member
Lots of old monojets out there. Just post in the want to buy forum. Also, ebay has a lot some one can buy for parts.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-15-2013, 08:19 AM | #5 |
Cool guys, thanks for the help and great suggestions!
