Old 05-14-2013, 11:53 PM   #1
JCampbell
Audio Installs
What are you guys running? Looking to upgrade the shortbed. I like it loud, fast, and metal.
Seriously, though...what kind of setups are you guys running in the single cabs that produce loud, clean, clear sound? The dually will be next, so maybe post up some Crew Cab/Suburban recipes, too.
JCampbell is offline   Reply With Quote
Old 05-15-2013, 08:46 AM   #2
Jonboy
Slots go on anything!
Re: Audio Installs
I had an '87 regular cab about 10 years ago that had a pretty simple setup in it that sounded pretty good. In the front, we took a pair of 5.25" components, and installed the woofers in the center location, and the tweeters in the factory 3.5 location. A set of 6x9's in the cab corners, an 8" woofer in a truck box and all run of of a 5 channel amp. The thing I liked best about it was that nothing was really cut up, but it would have been better to run the sub under the seat if possible. It wasn't an option so much back then, so the seat was pushed up a bit.
On my '74, I ran an ipod cable straight to a 4 channel amp with 6.6" components in the doors and 6x9's in the cab corners. It did pretty good for what it was, but you weren't going to go to any competitions with it.
Jonboy is offline   Reply With Quote
Old 05-15-2013, 09:03 AM   #3
BigMike608
BigMike608's Avatar
Re: Audio Installs
nice setups!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 05-15-2013, 01:15 PM   #4
JCampbell
Re: Audio Installs
So, you’re saying you ran the 5.25” woofers in the center speaker mount in the dash? Hmm. You didn’t have to cut it up to fit (not that it really matters to me).
I’m running those 6” kickpanel pods in my Suburban.
Old 05-15-2013, 02:22 PM   #5
Jonboy
Re: Audio Installs
Just minor trimming, IIRC. It's been a while. It was all under the dash pad, though.
Old 05-15-2013, 03:25 PM   #6
bohmankid
bohmankid's Avatar
Re: Audio Installs
I have four 6x9's in a truck box and one 8 inch sub in a truck box behind the seat. Only thing that sucks is no room back there to put stuff and the seat has to come forward so my 6-pack-impaired friends can't drive the truck LOL.
bohmankid is offline   Reply With Quote
Old 05-15-2013, 07:46 PM   #7
Kudzupatch
Kudzupatch's Avatar
Re: Audio Installs
Just put a Sound Ordnance power 8" sub under the seat of my Suburban and pleasantly surprised. Great tight bass and except for the ground wire running to the seat bolt there is no clue it is there unless you look.
Now if your young and looking to rattle the neighbors windows this isn't for you. It just can't create that much sound pressure. But if your looking for good sounding bass this thing can do that EASILY. My Suburban with all new speakers sounds as good as my Caddy with a Bose system.
Kudzupatch is offline   Reply With Quote
