Old 05-15-2013, 11:08 AM   #1
Southern Shaker
Frame/suspension questions
Hey guys,
i have my 71' c10 and a 69' CST donor with a Great Frame. i want to swap frames but i want to keep the 71 disc can i just swap over the front ends an rear ends ? Will it be hard? or can i just put the disc brakes an spindles on the 69 a arms ?
Southern Shaker is offline   Reply With Quote
Old 05-15-2013, 11:26 AM   #2
cdowns
cdowns's Avatar
Re: Frame/suspension questions
just remove the crossmember and discs as one unit and bolt to the 69frame
Old 05-15-2013, 11:32 AM   #3
Southern Shaker
do i take the whole set up a-arms an all ?
Old 05-15-2013, 11:33 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-15-2013, 11:35 AM   #5
Southern Shaker
ok, I know we had this talk about just driving it like it is ...but I Dont have anyother time to do this so im doing it now while i have the time.
Old 05-15-2013, 11:37 AM   #6
GASoline71
GASoline71's Avatar
Go for it...
Gary
Old 05-15-2013, 12:57 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
When we built my '67 on a '69 frame we took everything off a '71 so it would have disc brakes in front and 5 lug bolt pattern.
No matter which way you do it make sure you use the master cylinder off the disc brake system.
We did have to elongate a few bolt holes when we put the '71 cradle on the '69 frame if I remember right.
When we moved the '71 rearend over to the '69 frame we took everything from the '71 including the track bar and trailing arms.
It is a pretty straight forward swap though.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
