05-16-2013, 10:43 AM | #1 |
Maybe a dumb question 71-72
I gave someone a pair of front brake hoses for a 71-72 disc brake truck 1/2ton. Aftermarket braided stainless steel. They say the female end on one side doesn't fit. They didn't make two different steel line nut sizes, did they?
The hoses have the appropriate banjo fitting on one end and a 3/8" female inverted flare on the other. |
05-16-2013, 11:00 AM | #2 |
Re: Maybe a dumb question 71-72
i think the 1/2 ton and 3/4 ton used different sizes
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
05-16-2013, 11:07 AM | #3 |
05-16-2013, 11:16 AM | #4 |
VA72C10
maybe you have two different wheel cylinders so they have different sized attachment points?
Looking for a 67-72 swb or blazer project in or around VA. |
05-16-2013, 11:31 AM | #5 |
Disc brakes. Flex hose goes from caliper to tab on frame where hardline ends are.
Someone is telling me the hose fits one side but not the other. I have never seen a vehicle with two different sized hardline nuts. Both sides should be 3/8" inverted flare as far as I know. I'm asking if these trucks came with different sizes, pass vs drivers side. I don't believe they would have but I don't know every thing about these trucks. |
05-16-2013, 11:38 AM | #6 |
VA72C10
oops...forgot/didn't notice you said 71-72 w/ discs factory :facepalm:
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 05-17-2013 at 10:53 PM. |
05-16-2013, 11:59 AM | #7 |
Possible one hose has bad threads or other defect, problem is I'm dealing with someone that can't explain the problem, just "it doesn't fit one side"
05-16-2013, 03:06 PM | #8 |
My 72 1/2 ton uses two different part numbers for front beake hoses. I found out when i ordered hoses from the local parts house. Left side is one pn and right side is different. Same issue that op mentioned above.
Posted via Mobile Device |
05-16-2013, 03:12 PM | #9 |
http://m.napaonline.com/parts/PartsL...Ntk%3dCategory
05-16-2013, 04:12 PM | #10 |
Two part numbers because of the banjo head has opposite "tangs", I really doubt there's two different thread sizes at the female AN fitting but I'm not positive.
05-16-2013, 06:09 PM | #11 |
67-72 parts collector,…
There are two different sizes at the "hose-to steel line" connection.
(1/2-ton 2wd trucks) I've heard you can use 71-72 4x4 hoses to get them the same for each side. (as in converting from drum brakes to disc brakes)
05-17-2013, 06:36 PM | #12 |
Yea Tony, the 71/72 hoses use 2 different size female ends. One side has 3/8-24 and the other is 7/16-24 an female fittings.
05-17-2013, 10:43 PM | #13 |
I just replaced the front brake hoses on my '71 last weekend and the fittings that attach to the female end of the brake hoses are different from side to side. I believe the one on the pass. side was a little smaller.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
05-18-2013, 06:37 AM | #14 |
Watch out for your cornhole !
In reference to post number 2....
The difference between half and 3/4-1 ton hoses on 71-72 trucks is length. The heavy trucks used the exact same hoses as half tons, but with an added 3/4" of length. Those are the hoses I use on lowered trucks because the added bit of length makes the fit more comfortable on the dropped trucks. With drop spindles and drop springs on a half ton, the factory length hoses can get a bit taught for my tastes. The big truck hoses fix all of that. Posted via Mobile Device |
