05-16-2013, 10:20 PM | #1 |
headlight modification
i put silverstar sealed beams and relays in my headlight harness today, and my headlights are SUPER FRIGGIN BRIGHT!!!!!! thanks for the ideas guys!!
that is all.........andy
"DON'T TOUCH THE TRIM!!"-Early Kyler |
05-16-2013, 11:49 PM | #2 |
Re: headlight modification
I'd like to do mine.
Posted via Mobile Device |
05-17-2013, 12:48 AM | #3 |
I did the same with mine using hella's from amazon. 34 bucks a pop , bulb included. Sourced relays locally for $7. Wow what a difference over the old sealed beams. I will probably put silver star bulbs in, later down the line. If you do plan on this getting an old harness from a wrecker lets you maintain your stock one. Do your relay hacking on the wrecker harness and just tap into your truck one with some spade connectors. That way you can be back to stock in seconds.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
05-18-2013, 02:36 AM | #4 |
I am interested in this mod, i think? is this similar to what LMC offers as their headlight wire harness for direct connection to the battery or some such thing? please share the info on this mod. thanks.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
05-18-2013, 11:55 AM | #5 |
its the same mod i just got some relays off the firewall of a 91 suburban and made my own harness, i got a diagram off the 73-87 truck site, im sure there is one on this site too, to many guys here have done it!
05-19-2013, 03:12 AM | #6 | |
Any further info would be greatly appreciated. I have a 86 that i will be converting the front over to 89-91 and would love to do this mod while i have it apart. -Izzy
05-19-2013, 03:25 AM | #7 |
Izzy...where are you lost? The OEM setup routes all of the current that is delivered to the lamps through the dimmer switch and the headlamp switch. That circuit remains unmodified, it is used as the "low current" or control circuit for the relays. The high current side of the relays connect to the junction block on the firewall, or other more direct path to the battery and to the lamps.
I think the connections that you are looking for are the 11/150 and 11/12/150, where they used to route power directly to the headlights they are now used to control the relays. We do have a vendor that sells a rather impressive harness using high quality components: HERE
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
05-19-2013, 11:00 AM | #8 |
yup, thats the diagram i used! i was going to buy that harness but i didnt have the benny to blow on it!
05-19-2013, 04:48 PM | #9 |
As I posted in the other thread, pole 85 on the relays and circuit 150 at the headlights are chassis -ground. The do not need to be connected together as is shown on the diagram.
Only one fuse (30a) is needed. Split the wire or jumper between pole 30 on the relays. You can install your relays on the firewall where the harness connector is. Cut the harness right there and splice in your relays. There is plenty of slack in the wires. The relays are marked on the underside To make it easy, find the high beam hot wire (use a test light) cut it, the switch side goes to 86 and the highbeam side goes to 87. Lowbeam hot wire do the same thing on the other relay. 86 and 87 hook both pole 85 together and ground. Hook both 30 together, then to fuse and power. Use at least #12 wire. All the other wires are factory and should already be there. Nothing more is needed. Thats it.
08-03-2013, 05:31 PM | #10 |
I am revisiting this thread and while i am working under the hood on a few things.
after reviewing the info above i think i understand most of the wire routing now that i have a relay in my hand. My new question is about the relays themselves. first what relay is recommended for this mod? the relay i have in my hand at the moment is a BOSCH 0 332 204 150 The only difference between this relay and the pin-out imaged is that there is an extra pin, 87a thoughts? -Izzy
08-03-2013, 11:12 PM | #11 | |
The Bosch relay you have is ideally suited for this applacation. Its the same relay the aftermarket harness uses as well as most car alarms use.
08-03-2013, 11:45 PM | #12 | |
so yeah i have 3 relays and 3 wire connections. ready to rock and roll then. thanks again wraprail. -Izzy
08-03-2013, 08:04 PM | #13 |
i dont remember what mine are, like i said i got them off a 91 subs firewall buy the distributor
08-03-2013, 08:39 PM | #14 | |
-Izzy
08-03-2013, 09:58 PM | #15 | |
08-04-2013, 03:26 PM | #16 | |
These are from a 89 and 91 suburban. they are a 5 pin relay with each pin labeled A - F (there is no pin B however). I now have these and a set of the 5 pin bosh relays, I like the GM relays because they are weather proof and look factory if i can use them. do you know the PINOUT for these? are these the correct ones that you mentioned? -IZZY
08-04-2013, 10:19 PM | #17 | |
08-03-2013, 08:20 PM | #18 |
Has anyone tried the LMC headlight harness for single headlights? i'd like to try this on my '78, but some of the LMC parts i've recieved have been hit or miss. The dim yellow lights just ain't doing nothing for me at night.
08-03-2013, 08:40 PM | #19 | |
-Izzy
08-03-2013, 10:45 PM | #20 |
08-04-2013, 01:32 AM | #21 | |
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
08-04-2013, 12:27 AM | #22 | |
08-03-2013, 10:03 PM | #23 |
OK THEN! monday i will aquire these and start my harness mod. maybe i was looking at something different or maybe it just didnt click in my head when i was looking at them. I know that these are the fuel pump relays and such and are about 90$ (or used to be about 90$) at the stealer, so maybe that is why i shied away from them... who knows.
but now i can start the mod. -Izzy
08-04-2013, 10:13 AM | #24 |
however you do it this is a worthwhile modification, after i did this my brights light up signs more than half a mile away! no joke!
08-04-2013, 11:10 AM | #25 | |
Just don't follow clint's advice. lol
