62 - What 4-Way Switch Do I Need?
So the problem I am experiencing is that my Driver's front blinker lights up when I step on the brake, and my signals do not blink. I know that I need a new 4-way flasher, but when I was looking for a replacement I found many different flashers available.
Anyone familiar with a 62 4-way flasher I should use? Posted via Mobile Device
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
Re: 62 - What 4-Way Switch Do I Need?
Probably not the flasher, but rather the turn signal switch , itself may be malfunctioning.
Do you have an original steering column? |
#3 | |
Alot of guys with more experience than me have been able to clean up these switch when they start to not work correctly. I remember someone recently has having trouble finding the correct parts for the 62-63 column. I have a good switch for a 63 bu tthe cancelling part is broken. electrically it works great. It has the metal housing, not all plastic. Once you get the wheel off, take a couple pics and some of the guys can help identify which switch you have for sure.
PM me if you are interested in this switch, I really do not need it, I don't use stock columns. |
#5 | |
