Th350 or Th400...Realistically?
I'm not looking to start a huge debut over something that's been covered already. Just wanting advice for what actually works in our trucks.
I've got my big block out of my old bracket car I'm collecting parts to put it in my 86 long bed. Motor went 10.50-10.80 range in 3000lb car with a glide & brake. So I'm guessing 550-580hp. The truck is just gonna be a little toy to beat on on the street & track a few times a year. Probably shoot for 4:88's & 3000- 3500 stall. So what would you guys run for a trans? I have a good cooler & an lines already. Also, I have a th350 that works perfect with 75k on it that would be worth building. Since I'll be doing driveshaft work putting my 9" in I'm not even factoring that in on my decision. Posted via Mobile Device |
Re: Th350 or Th400...Realistically?
Th400 will be most reliable. While a th350 can be built to handle the power the th400 will easily handle that power. The only real downside to the th400 is that it eats a fair bit more horsepower than a th350 but for a street bruiser that shouldnt be an issue.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Thanks, that's exactly the debate I'm having w/myself right now. I'm really hoping someone can chime in on what they've used to make a 350 live behind a big block.
Money and a good bit of it! A th400 will handle so much more than a th350 in just stock form. I love a 350 but the 400 is way more reliable and thats what counts when on a budget.
Billet drum an input shaft on the TH350 for sure for starters. A lot parts will need to be upgraded for sure.
It's Better With Nitro
Since you posted your question in the race forum, I would go with the TH400. It'll take more money to make the TH350 handle the torque levels (it'll be the torque that will be the primary factor for longevity) in a mild race application.
I've run Mike's Transmissions (http://mikestransmission.com) in all of my race cars with automatic transmissions, and Mike Stewart will not build me a TH300 or 700R4 for my Pontiacs. As a side note, I have run his TH400s behind my blown Pontiacs in nostalgia eliminator with zero trans failures - broke just about every other component, but not the transmission.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
![]() Join Date: Jun 2013
...don't want a big debate either-
i had JW Performance build my TH350: fully rollerized, ultrabell, 36 element steel drum, 2.75 low gear planetary, performance valve body, strip-sprag, etc. it is some of the best money i have ever spent- i am confident it could take just about anything you can throw at it... it's just money....cost was right at $3300 shipped |
#8 | |
The trans is $1895 today. Having a TH400 rebuilt locally is even cheaper.
...generally agree with related comments...if/when budget is a concern the th400 is more cost effective- wanted to answer original question, though, so i was telling you what and how much/about my JW th350...can be done-just costs more; like what was being said.
if your th400 core/internals are in good shape and you have the opportunity to work with a builder local whom you trust, you can prob do something adequate for your application like this (just trying to help out): kevlar/kolene kit: 300 perf valve body: 200 converter: 600-700 rebuild labor: 325 -you can prob complete this with $1700 or less using your core and have a mean th400 for nearly half the cost of a "built" th350 ...also i like coan, but they didn't have all the parts i wanted for my th350- so i went with JW and am quite pleased with the results of my decision |
$3300 is a little out of my budget for trans only. Im thinking around $2000-$2500 for trans & converter. I've managed to come up with a low mile stock rebuild th400 from a buddy. I'll probably take it to a local racer that builds some good transmissions & see what his opinion is on what it will need. Then probably get my stall ordered.
A well built th400 with a good (read 7-800 dollar) verter could be done for under 2 grand without much of a problem.
I really liked the Coan converter I had with this motor & the glide but it is waaaaaay too much for mainly street use. I'll probably call them again when the trans is done. Top notch folks to deal with in my opinion.
TH400 all the way!
Like others have said, a TH350 will handle a LOT, but it takes a LOT of $$$$$!! You could buy a few nice TH400's for what you will have in one race built TH350. Do some googling for a guy that goes by the name of "Jakeshoe", he has some awesome writeups on the 400's and he has a wealth of knowledge. He claims that the difference in power consumption between the 2 transmissions will not exist untill you start getting below tens in the 1/4 mile. He has it all in detail so I'll let ya do the digging on that. He usually frequents the hotrodders.com and other forum boards..
'66 SWB BBW Custom cab factory A/C OEM roller 350/TH400 C-notched and bagged Frame off in progress! '69 Camaro Original 327 4 speed - completed |
