Old 05-23-2013, 01:44 AM   #1
74 stepside
74 stepside's Avatar
Forward Porterbilt arms on a Square
Anyone have the Porterbilt tubular a-arms on the front of a squarebody? They said it pushes the wheels forward to help center the wheels. Id like to see how much of a difference it makes before I make a purchase..
74 stepside is offline   Reply With Quote
Old 05-23-2013, 05:30 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Forward Porterbilt arms on a Square
Porterbuilt makes many different a-arms.
If you are thinking about buying a set for a stock crossmember truck,...
you have to ask for their "Forward Series" a-arms.
A Dropmember equipped trucks use a set of regular Porterbuilt a-arms,...
since the Dropmember itself, moves the wheels forward.
(I didn't want you to think that ALL Porterbuilt a-arms move the wheels forward)
Keith
Convert to disc brakes.
Old 05-23-2013, 12:54 PM   #3
74 stepside
Thats what I was asking for. The title of Forward arms. Wanted to see them on a truck..
Old 05-23-2013, 07:45 AM   #4
andrewmp6
They are only one inch forward which don't sound like much,But when your lowered with big wheels its makes a big difference and clearances.
Old 05-23-2013, 02:52 PM   #5
lolife99
lolife99's Avatar
This one has a Dropmember,... but it would be really similar to this.
(only picture I can find of these trucks air'd all the up)
"Wheel Placement" of the front wheels is so much better.
Keith
Old 05-23-2013, 03:50 PM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
Here is an unfinished one of my son's '82 with the Lower Forward Arm only. The tire is a 275/45r20 in this picture....
Here it is sitting on the weight of the truck at ride height. He is running the coils spring, not an air bag. There is a billet retainer that is available separate to use coil springs insted of bags. The tire is a 245/45r20 in this picture. We will end up running 255/40r20's when we get it on the road...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-23-2013, 03:57 PM   #7
cory d
cory d's Avatar
relocating the lower ball joint 1" forward will also give you some much needed caster gain so you dont burn the front tires of from under steer
cory d is offline   Reply With Quote
Old 05-23-2013, 05:27 PM   #8
74 stepside
Thanks guys. It makes more of a difference than I thought. I want to run their forward arms off my stock crossmember. Time to start saving up...
